My first planer - Router Forums
post #1 of 13 (permalink) Old 12-05-2012, 05:17 PM Thread Starter
Smile My first planer
Amazon had a very short sale on the DW735X with the Dewalt $25 off coupon. Total deal at $480 including shipping. I also got the DW7350 stand a few days later also with the coupon discount.
Stand took several hours to put together (lousy instructions) but with some luck it came together perfectly. The extra shelf is very nice too. Only took 15 minutes to put the planer on it.
Now after reading the planer instructions I think I have this figured out. However I am a visual person. Does anyone know of any instructional videos on how to use this planer?
Thanks - Keith
powerscol is offline
post #2 of 13 (permalink) Old 12-05-2012, 07:34 PM
Marco's Avatar
Congratulations Keith on the planer and stand, a solid buy.
As for video's I would be surprised If you tube did not have one on the 735. Most planers are very similar to operate so once you know where everything is and are able to run it safely check out the various tips both written and on video to avoid snipe..... and enjoy!
Galatians 5:13
Marco is offline
post #3 of 13 (permalink) Old 12-05-2012, 10:03 PM
First Name: Earl
Beyond the obvious "don't put your hand...", one of the best tips is to never try to take too much off at a time--several thin shaves. Another thing to watch is the grain direction--plane with it, not against it. Nice planer, i really like mine a lot.
greenacres2 is offline
post #4 of 13 (permalink) Old 12-06-2012, 07:44 PM
JFPNCM's Avatar
First Name: Jon
Default Possible DW735x vieos
Suggest you check out "Planer.mov" on YOUTUBE
Overall reasonably informative.
I agree re the instructions for the Dewalt table are basically useless and the Manual for the 735x is not a lot better. A great combo though.
Jon
JFPNCM is online now
post #5 of 13 (permalink) Old 12-06-2012, 08:01 PM
papawd's Avatar
First Name: warren
Great buy
papawd is offline
post #6 of 13 (permalink) Old 12-10-2012, 06:49 PM Thread Starter
Thanks folks. I got it fully assembled watched several videos and ran some sample pieces. I could not be happier - however Santa needs to bring the wife a pair of hearing protector ear muffs. I did wear mine - but even with the doors closed in the next room it was too loud for her. Thanks again for the tips
post #7 of 13 (permalink) Old 12-10-2012, 06:55 PM
First Name: Earl
Loud is relative--My 735 is near-silent when compared to the Delta 12" i was using before!!
post #8 of 13 (permalink) Old 12-17-2012, 10:24 AM Thread Starter
Been trying out the various settings and dialing in the calibration. Factory setting are spot on - its my eyes that I need to adjust. Stand is solid when operating too and is at the correct height for me. Chip extraction is fantastic. Neighbor has an old Delta that leaves a lot of dust on his boards. I use a 25year old Sears shop vac - one of the 5HP models - however, note-to-self, is I cannot plug it and the planer into the same 20 amp circuit :-) It was a bit of an effort getting it connected to the adapter though - pipe diameters were a bit of a mismatch (or it could be my old hose).
One question - is the Wixly gauge worth getting if I am just doing occasional use? My eyes are not the greatest now, so looking for a bit of help. I need a large fount read out.
post #9 of 13 (permalink) Old 12-17-2012, 10:32 AM Thread Starter
One other question - is there a good 90 degree adapter for connecting my shop-vac to the vaccume/chip port? If so where do I get and what size? I would like to get my shop-vack hose more out of the way. Thanks - Keith
post #10 of 13 (permalink) Old 12-17-2012, 10:51 AM
JFPNCM's Avatar
First Name: Jon
Regarding dust collector fittings, unlike pipe, there is no consistency in OD, ID measures across manufacturers so proceed with caution when buying. A real sore spot from my perspective. The lowest cost choice would be a 90 degree PVC elbow from the hardware store assuming one will fit. If not Rockier and other wood shops carry adapters.
A note of caution, that planer wil fill a shop vac quickly. If it has enough power you may want to add in a chip collecter.
Cheers
Jon
used planer reikimaster Tools and Woodworking 19 04-22-2012 02:12 AM
Clean The Rollers On The Planer Jerry Bowen Tools and Woodworking 0 04-20-2012 11:24 AM
Planer Blade Sharpening Jigs Makes? Gaia Pyrography and Carving 18 03-18-2012 11:02 AM
Wonderful Wife (new jointer and planer) xplorx4 Tools and Woodworking 11 11-08-2009 03:29 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
