Joining Boards Together For Door Panel - Router Forums
post #1 of 11 (permalink) Old 01-15-2013, 03:57 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Joining Boards Together For Door Panel
I'm into wood carving and making doors. To make a large panel for a exterior, interior house door? Joining boards together, any pointers of how wide I have the boards I glue up? Would the way to go be using spline joints to glue the boards together? Alternating grain pattern on the end of each board to reduce any tendency to cup, does this also apply to to quarter sawn timber? Use the pipe clamps, one head on one side, then the next on the opposite to even out any stresses in the wood and further reduce tendency to cup? Clamping cauls?
Any advice much appreciated.
Gaia is offline
post #2 of 11 (permalink) Old 01-16-2013, 07:45 AM
First Name: Art
I would stick with boards about 6" wide and although it is often said to rotate the grain to prevent cupping I have never experienced it. Keep the boards flat by putting a piece of wood over them once they are glued up. It also helps to put some paper under the board in case there is glue squeeze out. Have your clamps set before doing the gluing and don't over tighten them. If you can put glued up panel through a planer that would be the best otherwise just sand them smooth. Splines would be fine but not necessary as long as your edges are straight and smooth.
mgmine is offline
post #3 of 11 (permalink) Old 01-16-2013, 08:06 PM
Phil P's Avatar
First Name: Phil
Hi Peter
For a door panel I'd say get the hearts all on the same side; two reasons - firstly if it moves in service a panel with a single bowed surface looks less disconcerting than a washboard surface if hearts/backs are alternated, secondly if the timber is crown or flitch cut (and many pieces are) then getting a visual match with two pieces should be much easier (not to mention consistent stain/finish absorbtion rates and evenness of colouring when finishing). Where quarter sawn is used on doors it is generally only available in oak - and even that is pricey. Sometimes used on frames rather than panels for stability
If you use clamps then all same way round but with a piece od something like 2 x 1in softwood cleat up each edge to even out the pressure (avoids crushing the fibres and removes metal to timber contact - not good with timbers like oak which can blacken). One tip about clamps - coat before use with Johnsons wax furniture polish or similar, especially the threads - makes cleaning-up drips afterwards much, much easier. A hardboard board waxed in the same way can be placed on the bench to protect it, too, although Visqueen (builders DPM polythene) dioes just as well. Cauls shouldn't be necessary, just don't go mad applying too much pressure.
This sort of task was often done in the past with a plain jointed board edge and a rubbed joint with just a couple of joiner's dogs (see below) knocked into either end of the boards. If you do use a water based glue such as PVA and loose tongues (spline joints) leave the boards an extra day or two to dry out as the moisture trapped in the joint can cause slight swelling and may take a couple of days to dissipate. Saves having to sort out hollow joints caused by planing-up prematurely whilst the joint is still slightly swollen
Above: Joiners dogs
BTW cramped joints were traditionally shot slightly hollow (0.3 to 0.5mm or so) whilst dogged joints were worked with one side slightly crowned in the middle of the joint to give a slight gap at each end (again 0.3 to 0.5mm at each end). Light cramping then pulls the joints up nicely
Regards
Phil
Phil P is offline
post #4 of 11 (permalink) Old 01-18-2013, 02:46 PM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by Phil P View Post
Hi Peter
Above: Joiners dogs
Regards
Phil
OK thanks as ever for a knowledgable reply. If I use spline panel joints what size should I make these? The size of the slot and stub themselves in relation to the thickness of the panel boards themselves? Would I use cauls on spline jointed boards?
Cheers.
Gaia is offline
post #5 of 11 (permalink) Old 01-18-2013, 02:49 PM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks.
Gaia is offline
post #6 of 11 (permalink) Old 01-19-2013, 12:41 PM
Phil P's Avatar
First Name: Phil
Hi Peter
Splines are generally made from standard available stuff and are generally proportioned similar to a mortise and tenon joint (a loose tongue is after all just another form of tenon). That means about 1/3 of thickness. So if your panels are 25mm/1in you are looking at 8mm plywood, although 6mm (1/4in) or 9.5mm (3/8in) would also do. Just make sure that the splines are a snug fit and not rattling around (if needs be rout the grooves tight and sand the splines to fit) . In terms of depth the splines need only be 12 to 20mm wide overall with 1 to 2mm extra width in the slots - their purpose is to keep the joint straight whilst the glue sets - they don't add to the strength of the joint and can detract from it (especially if overly wide) which is why a lot of traditional work uses a rubbed plain butt joint. If your edges are dead square (which they need to be be to joint them properly) cauls shouldn't be necessary provided you don't overcramp. The only time you should need cauls is on thin timber, 12mm (1/2in) or less, but you'd never really use splines on anything so thin
Please note that I don't use the word "stub" - it is not relevant in this context (a stub tenon is something completely different).
Regards
Phil
Phil P is offline
post #7 of 11 (permalink) Old 01-19-2013, 05:47 PM
Hi
Not to sure why you want put a spline in a panel doors a butt joint will work well the norm..the door frame is doing most of the work for you.
post #8 of 11 (permalink) Old 01-20-2013, 03:09 PM Thread Starter
Gaia's Avatar
First Name: Peter
Hi
Hi Bob,
The slot in the frame allowing for expansion and contraction of the panel. Could the expansion slot cause problems with a butt jointed panel?
Gaia is offline
post #9 of 11 (permalink) Old 01-20-2013, 03:28 PM
with the glue we have now days it will hold a butt joint easy but the strips is backup way to hold it in place as well..
200ct. Panalign Strips-Sommerfeld's Tools For Wood
Hi Bob,
post #10 of 11 (permalink) Old 01-20-2013, 03:35 PM Thread Starter
Gaia's Avatar
First Name: Peter
Hi Peter
Regards
Phil
Whats your view on the following?
" The better the glue penetrates into the pores of the wood, the stronger the joint will be. "
" Broad surfaces of close-grained hardwood having a shiny surface are usually carefully roughened with a fine toothing plane blade previous to glueing. "
Cheers.
Gaia is offline
Alabama Corn Hole Boards grbrico Show N' Tell 6 07-04-2012 09:19 PM
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
First Inlay Attempt/ cutting boards bcfunburst Show N' Tell 3 01-21-2012 09:57 PM
First Cutting Boards Soapdish Show N' Tell 3 02-03-2010 10:35 AM
Jointing long boards Jtomwoods Table-mounted Routing 8 05-25-2008 09:05 PM
