I need help with mounting router to table. - Router Forums
post #1 of 6 (permalink) Old 02-15-2013, 11:59 AM Thread Starter
First Name: Trevor
Default I need help with mounting router to table.
I have never mounted one before what are the step by step instructions on how to do this?
I have a Bosch 1617evspk & Grizzly table T10432.
TrevortdogR is offline
post #2 of 6 (permalink) Old 02-15-2013, 06:00 PM
I looked online at the table and the description says it has a universal mounting plate which means that the bolt pattern that holds your baseplate on should match one set of holes on the router table plate. Take the screws and plate off the bottom of your router and try matching your baseplate hole pattern to the router table plate. The screws may not be long enough to mount your router to the table insert in which case you would need longer ones and they will most likely be metric.
post #3 of 6 (permalink) Old 02-15-2013, 08:31 PM
GulfcoastGuy's Avatar
First Name: Patrick
Here's a sticky that Mike made on just that subject.
http://www.routerforums.com/table-mo...ing-plate.html
I've got the same plate and router in my table. I used a inlay kit bushing instead of the Rousseau centering kit 'cus I had one on hand.
GCG
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #4 of 6 (permalink) Old 02-15-2013, 09:09 PM Thread Starter
First Name: Trevor
I did do the install but it did not go as well as I hoped. The table plate is not flush all the way around like before.
I'm not sure if I need a new table plate or if it could be fixed.
post #5 of 6 (permalink) Old 02-15-2013, 09:47 PM Thread Starter
First Name: Trevor
GCG
I wished I had know about the kit before I did mine.
post #6 of 6 (permalink) Old 02-16-2013, 07:39 AM Thread Starter
First Name: Trevor
After a tip on the tables directions I read them again and found out how to level the plate and everything seems to be pretty flush.
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 02:32 PM
