craftsman router problems - Router Forums
post #1 of 4 (permalink) Old 02-15-2013, 08:36 PM Thread Starter
b&v
First Name: b
Default craftsman router problems
Greetings; I have a 3/4 hp fixed base router that worked fine new, a couple years ago. It has had very little use. Now, when I turn it on it goes up to full rpms then decelerates so low that it wont work on the wood. I checked the bushings & they're fine. Is anyone familiar with this kind of problem?
b&v is offline
post #2 of 4 (permalink) Old 02-15-2013, 11:46 PM
Welcome to the forum. So far I have not had the issue with my routers.....
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 02-16-2013, 12:51 PM
First Name: Duane
Sounds like a bad speed control module.
Dmeadows is offline
post #4 of 4 (permalink) Old 02-16-2013, 12:54 PM
First Name: Gene
Thats why I quit having Craftsman routers about 20 years ago and started using Bosch . The one I had the bearings got bad and I tried to fix it my self and the bearings were only available at Sears made special for Sears that did it for me . I have not had a problem with Bosch .
Genel41 is offline
Problems with my Craftsman Router bulldogrg Portable Routing 12 12-20-2019 12:20 PM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Craftsman Tablesaw with Router wing rjhanby Table-mounted Routing 1 08-27-2009 11:10 AM
