A few questions from a newbie - Router Forums
post #1 of 14 (permalink) Old 02-26-2013, 04:39 AM Thread Starter
First Name: Ezra
Default A few questions from a newbie
Hi
I have just completed building my long awaited workshop (15 years in waiting) prompted by a new venture. I have had some experience in wood working over the years mainly at college as an art student.
I am having square Marine Plywood panels cut to size by my local wood merchant that will arrive with nice sharp edges.
1. I need to sand the edges in preparation for wax polishing which I will be doing with a cotton buffer attached to a power drill after a sealer has been applied and rubbed down. I intend on clamping several panels together to increase productivity. In an attempt to make the process as speedy as possible I would like to sand the edges by some automated means. Can anyone suggest a method other than hand sanding with a block or is that simply the best option?
2. I would like to take some of my square blocks and round the corners off using a router. Can anyone suggest a method/tutorial that I can use to produce multiple panels of this type?
3. Lastly, can anyone suggest a method of clamping the several panels together that will allow me access to all 4 edges to sand and polish without having to reset the clamps as I work my way round each edge?
Ezra
theRushen is offline
post #2 of 14 (permalink) Old 02-26-2013, 05:14 PM
Welcome to the forum, Ezra.
Sydney, Australia
jw2170 is offline
post #3 of 14 (permalink) Old 02-27-2013, 04:34 AM Thread Starter
First Name: Ezra
Hi james
Thanks for the welcome.
Looking forward to getting involved.
Ezra
post #4 of 14 (permalink) Old 02-27-2013, 07:43 AM
Country: South Africa
First Name: Mark
Screw the pieces together and work all edges at leisure. When done plug the holes with a small dowel, but this could take as much time as moving the clamps!
markristow is offline
post #5 of 14 (permalink) Old 02-27-2013, 11:26 AM
JOAT's Avatar
First Name: Theo
Welcome aboard. What are you making that you need marine plywood for? That's usually more expensive then other plywoods. You could always make a large belt sander for sanding the edges, or a large sanding disc. But I would think that fastening the pieces together, sanding, then unfastening, would take longer than just sanding one at a time. Certainly would for me with what I do at any rate. And pictures are always helpful.
JOAT is offline
post #6 of 14 (permalink) Old 02-27-2013, 02:59 PM
First Name: Dick
Hi Ezra, are the panels large enough that you could use a router table? I don't think anyone can help without more details. I understand you may be creating something unique and want to keep it to yourself, but without understanding exactly what you want to accomplish it's hard to offer help.
Willway is offline
post #7 of 14 (permalink) Old 03-01-2013, 02:54 AM
First Name: DAVID
Welcome, Ezra
IRONMULE31014 is offline
post #8 of 14 (permalink) Old 03-01-2013, 11:33 AM
Hey, Ezra; welcome!
What size are these panels?
Are you sanding the tops/bottoms as well?
How are you planning on finishing only the edges without straying onto the tops/bottoms?
It sounds like a perfect application for a stationary belt (or disc) sander, assuming the panels aren't huge... one at a time
G1531 6" x 80" Edge Sander
DaninVan is offline
post #9 of 14 (permalink) Old 03-05-2013, 04:52 AM Thread Starter
First Name: Ezra
Hi All
First up many thanks for your replies. Your time considering my issues is very well appreciated.
So firstly...
What am I aiming to achieve? Hand crafted wood mounts for placing photographic prints on to. I intend on offering several different mount options which will include clear polished and tinted polished edges (18mm +). Some unpolished with rounded (routed) edges/corners (9mm). I am well aware that MDF is the most stable medium for prints and plywoods have issues over warping however MDF is soulless. I intend on finding a way to make plywood work for me. Like all woods, in moist conditions they warp. From what I have read I suspect laminating sheets of ply will ultimately be the answer to stabilising ply as effective photo mounts.
JOAT
Actually I am experimenting with both Marine and Birch Plywood, both hardwoods of course. The reason for Marine is twofold. Firstly because I am interested in the variation of hardwood veneers found in marine ply which when sanded and polished are beautiful and every sheet seems to be different and they make an excellent background to prints. Also marine ply tends to be almost cavity free as does birch ply.
Willway
Yes they are. Size I am working on at the moment are (smallest 170 x 170 mm largest 500 x 500 mm although up to 1000mm would also be available) I have recently bought, off ebay, a router table and low wattage (700) router, which may well not be sufficient but i'll find out soon enough. My plan it to buy good quality cutters. This seems pretty consistent which much of the advice I have read on routerforums. You can get away with poorer quality router but not so table and cutters.
Are you suggesting I use the router table to prepare edges for polishing. If so how?
DaninVan
No just the edges
I am not too bothered about straying as I want the panels to be obviously hand made. Showing process helps to demonstrate that. On one side will be affixed a print in any case.
If I were to clamp together several panels to work on at a time then this would prevent polish from being placed on the sides for the interior panels in any case.
This looks perfect although a bit outside my startup budget. One for later maybe. I have identified similar but on a smaller scale Clarke CS6-9C Belt & Disc Sander - from Machine Mart
markristow
Not an option for my purposes.
Thanks again for all your thoughts so far.
post #10 of 14 (permalink) Old 03-05-2013, 07:02 AM
Ezra, what size radius do you want on the corners?
slot cutter newbie questions turbo6justin Table-mounted Routing 16 03-27-2014 08:33 PM
Newbie with a few questions.. nickhead New Member Introductions 8 01-20-2013 03:21 PM
Rob- newbie with questions rpto New Member Introductions 9 12-21-2010 10:02 PM
Newbie and Questions joshes New Member Introductions 4 05-18-2010 02:33 AM
Hello All & Some Newbie Questions! RBM New Member Introductions 3 08-03-2009 01:48 AM
