Using drill press - Router Forums
post #1 of 15 (permalink) Old 02-28-2013, 02:31 PM Thread Starter
First Name: Henry
Default Using drill press
What are the benefits and problems of using drill presses with router bits?
OIB-HENRY is offline
post #2 of 15 (permalink) Old 02-28-2013, 02:45 PM
First Name: tom
not enough rpm.
tjstamp is offline
post #3 of 15 (permalink) Old 02-28-2013, 03:20 PM
bobbotron's Avatar
First Name: Rob
Not great lateral bearing support in a drill press too - straight up and down is good, but side to side not so much.
bobbotron is offline
post #4 of 15 (permalink) Old 02-28-2013, 03:46 PM
Henry, drill press and router are two different machines for different purposes.
The router bits is designed to spin at 8,000 to 35,000 RPM and the router has bearings designed to take the sideways thrust of the cut.
The drill press runs much slower and is designed for vertical plunge only.
I see no real benefit in using a router bit in a drill press.
Sydney, Australia
jw2170 is offline
post #5 of 15 (permalink) Old 03-01-2013, 09:42 AM
First Name: Paul
And how about safety?
Wow! I can't imagine the damage I would do to myself with either the bit (any bit!), the workpiece that would surely get out of hand, or even the chips that would be flying!
PRDarnell is offline
post #6 of 15 (permalink) Old 03-01-2013, 09:43 AM
roxanne562001's Avatar
First Name: Roxanne
The drill press turns to slow. I tried to do that a while ago using a mill type vise. The 16 speed drill press on high speed. The side thrust and chatter made the #2 Morris taper 5/8" chuck come loose and drop down out of the drill press causing a very dangerous heavy chuck flying around. I was lucky not to be injured. The drill press is not made to be a router or a milling machine. Speaking from experience I do not recommend it!!!!!
roxanne562001 is offline
post #7 of 15 (permalink) Old 03-01-2013, 10:27 AM Thread Starter
First Name: Henry
Thanks group for your comments. My Delta bench drill press chuck is pressed onto a tapered shaft and has occasionally come loose, even without a router bit. I will stay away from considering using a drill press as a router. Henry
post #8 of 15 (permalink) Old 03-01-2013, 11:07 AM
First Name: Bob
Default Using router bits in a drill press is not recommended
Henry ~ I agree with everyone else about NOT using router bits in a drill press. I raised this question in a previous thread because the old Craftsman drill presses from the late 40's and early 50's provided router bits and collet adapters for the chucks. The selling point for Sears was that you could see what you were routing (similar to an overarm pin router) and by having accessories made the drill press more versital. Here is another link. I inherited my drill press from my father and every once in a while I am tempted to use the routers bits for it. But the wise advice from the veteran members of this form, especially Bj, have kept me out of trouble. As they said on the ol'e Hill Streets Blues TV program: "Stay safe out there."
Web Shepherd is offline
post #9 of 15 (permalink) Old 03-01-2013, 03:33 PM
JOAT's Avatar
First Name: Theo
Oh, it can be done, and done safely. BUT, it will take a LOT of modifications, meaning a LOT of money invested in doing it. Unless you've got a ton of talent, and a ton of money to invest in doing it, and just want to do it for doing it, I go along with the rest of the gang - not worth doing.
JOAT is offline
post #10 of 15 (permalink) Old 03-01-2013, 03:45 PM
What might work for you, Henry, is a flexshaft and burrs, sanding discs and drill bits.
Not exactly routing, but if you were thinking of doing a bit of carving and engraving (?)...
Flexible Shaft for PTO Hand Tools: Power Drill, Drillpress Flexible Shaft
DaninVan is offline
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Picture of my Drill Press recently finished RLego Tools and Woodworking 5 07-12-2013 03:13 PM
Drill Press Table TRN_Diesel Show N' Tell 33 01-02-2013 11:46 PM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
