Buying advice - Router Forums
post #1 of 18 (permalink) Old 03-09-2013, 12:35 AM Thread Starter
First Name: Jay
Default Buying advice
A hate to ask this question, because I'm sure it's been asked hundreds of times before. I've looked at a few recent threads, but I'm not sure I got a precise answer.
I'm in my early 20's and would like to purchase a router to last me a long time. My next project is just building a desk, but I'm OK with spending extra now for something that will give me reliability, flexibility, and ease-of-use in the future.
So let's say my budget is anywhere between $150-$450 for a router, and additional funds for a router table. What would you get?
pint is offline
post #2 of 18 (permalink) Old 03-09-2013, 03:17 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
My precise answer is get a Triton TRA001 (2200w ) plunge router. It may seem a bit big but when you install it under a table it handles anything. Has an above table winding mechanism for fine adjustments.
If it's out of your price range then the next one down. I think it may be the MOF001.
cagenuts is offline
post #3 of 18 (permalink) Old 03-09-2013, 04:43 AM
+1 on the Triton.
Welcome to the forum, Jay.
There are so many models out there that fit the bill, you will get many recommendations.
Sydney, Australia
jw2170 is offline
post #4 of 18 (permalink) Old 03-09-2013, 05:47 AM
First Name: Earl
Welcome to the Forum.
If i had the high end of that budget just for the machines (bits are a different story), i'd buy 2 decent routers from the same family. Would enable a table/handheld most of the time and then a second table for part of the time. Same family so that you could interchange bases, plates, edge guides, etc. easier. I'm partial to Bosch routers, so for me it would be the Colt and a 1617, both with fixed and plunge bases. The newer Bosch MRC23 would be a candidate for me as well, though it's still pricy.
Dewalt makes a good series as well. Find a fit that feels good to you.
earl
greenacres2 is offline
post #5 of 18 (permalink) Old 03-09-2013, 05:53 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Welcome, but I beg to differ. Triton is a good router, Porter cable is a good router as is Dewalt, Freud and a host of others. Look at the manuals and the exploded drawings for the repair parts. See which has the easiest bearing & brushes to obtain and are of standard size. Look at the dust shielding as fine particles will always find a way in and finally decide if you want one that is stationary on the table as this allows you to purchase only the motor (eliminates a lot of moving parts parts) or if you want to purchase a second router to avoid the issue of removal and replacement when you cannot use the table mounted unit. And please think about what you will actually use this purchase for and in what country. Triton is a great router until you try to find certain spares, the same can be said of all routers depending where you live.
Good Luck - Baker
rwbaker is offline
post #6 of 18 (permalink) Old 03-09-2013, 06:34 AM
First Name: Art
I would guess you will get as many recommendations as people have routers. If I were in the market I would buy the most powerful name brand that I could. Don't worry about the weight if you are going to use a table and don't worry about finding something that has two bases. When the time comes to get a hand held one there will most likely be improvements to what is out there today. As far as parts goes Richard has a point which to me means don't buy a Craftsman. Sears is known for making it difficult to find aftermarket parts. As far as the table goes make your own and if the router you choose doesn't have the capability of being raised from above then get one that is compatible with the Router Raizer.
mgmine is offline
post #7 of 18 (permalink) Old 03-09-2013, 09:00 AM
First Name: Paul
To expand what Art just said about Sears Craftsman,
Sears (now owned by K-Mart) has always contracted with manufacturers to make tools for them. By the time they told the manufacturer what they wanted it to look like and what price they wanted to sell it for the manufacturer inevitably made it different from their own tool of the same production year. Some parts would be interchangeable with the OEM and some would be brand specific.
So, you see what happens ten years down the road. You might be able to get replacement parts from Sears but probably not. When you go to the manufacturer for an OEM part you might find it. You might not if it is one of those made only for the Sears model. This often happens with shields, handles, guides, etc. Then you end up looking for used machines to cannibalize in order to find parts.
While one of my hobbies is restoring old "tools with tails" I sometimes have to wait years before I find parts.
So... buy a brand name you expect to be around in 20- 30 years. If not for yourself then for the next owner.
JMHO
Paul
PRDarnell is offline
post #8 of 18 (permalink) Old 03-09-2013, 09:20 AM
First Name: Duane
JMHO
Paul
Yep, thats why we see posts from people looking for NLA part for PC, Bosch, Makita, and others! Anything past 10 -15 years old is hit/miss at best... especially if electronics are involved. Many machines of most major brands last 15 - 30 years with no need for parts. My 18 year old Craftsman router and 35 year RAS are examples!
If you make your power tool decisions on long term parts availability... better stick with hand tools. This is getting more and more the case with global manufacturing and shorter model change cycles. NO manufacturer will retool a production line to make you one part.
For larger machinery, there are some small 3rd party shops willing to manufacture parts. For smaller commodity tools, that isn't practical, again especially for electronic module like speed controls for routers.
How many cordless drills are laying around due to it being cheaper and quicker to just buy another? I would personally not make this my primary purchasing concern!
YMMV
Dmeadows is offline
post #9 of 18 (permalink) Old 03-09-2013, 09:35 AM
Shortslvs's Avatar
First Name: Fred
I would like to mention briefly my experience with Triton. I have know idea what the situation will be in 10 years, but I bought a used 3 1/4 horse Triton. It was missing several parts. Here in the US they are distributed by Kreg (something I learned on this forum ) anyway I contacted Kreg and gave them the list of what I needed. 12 hr work day later I get a call from the kid who took my parts list and he tells me he has shipped them all out. I got that on voice mail. I called back the next day and got a hold of this guy that worked 12 hours on my order and asked him what I owed him. He said it was on the house. Easiest replacement parts I ever got. Triton and Kreg gained a customer for life . So if you are looking don't overlook Triton just because they are not US based.
My Two Cents
Shortslvs is offline
post #10 of 18 (permalink) Old 03-09-2013, 12:11 PM
First Name: Eloy
I have 5 Triton's never a problem except collets. Kreg is great on support the best I have seen in the industry. I own 30 something routers and I like to mix up the brands as depending on the application some brands are better than others for different applications. Granted mixing up brands adds a little work but it is good to have the flexibility to have different options to match the job.
damnitboy is offline
Making mantel clock--need advice on routing groove into frame for glass insert IronHorseDriver Starting Off 5 02-19-2013 02:41 PM
In router table buying mode . . . wtbuchanan Table-mounted Routing 3 12-07-2009 02:20 AM
Looking for some advice on buying template guides Bonehead V.2 Guide Bushings and Templates 9 08-28-2009 09:08 AM
Router buying advice welcomed. Joeofalltrades General Routing 12 07-07-2008 10:58 PM
Advice on buying router table jayhawk Table-mounted Routing 16 03-24-2005 11:46 AM
