Squaring Cabinet Doors - Router Forums
post #1 of 12 (permalink) Old 04-01-2013, 08:26 PM Thread Starter
First Name: Nick
Default Squaring Cabinet Doors
I am making cabinet doors for the kitchen and my first pair didn't come out quite right. I am using Blum hinges so there is a little room for adjustment however I want to only use those as a last resort. Is there certain jigs that you make or tools that you use to make sure the doors are square when glueing and clamping? These are shaker style doors.
farmernick is offline
post #2 of 12 (permalink) Old 04-01-2013, 09:55 PM
N'awlins77's Avatar
First Name: Lee
I made thirteen shaker style doors for my cabinets (first picture shows six of them), and I didn't use anything to square them up. Just made sure my cuts were squared, then used pocket holes screws to tighten them up. I don't remember if I ever put a square up against them, but I think I did, at least in the beginning. But they all look square enough on the cabinets! (second picture) ;o)
Name:	07-Doors re-cut 1.jpg
Name:	040-Gettin' close.jpg
N'awlins77 is offline
post #3 of 12 (permalink) Old 04-01-2013, 10:46 PM
MEBCWD's Avatar
Hi Nick,
First you need to make sure your parts are the same length before you try to glue them, height the same, width the same.
To see if the door is square measure across the diagonal from corner to corner. They should be the same measurement. if they are not then adjust your clamps until they match.
You can also check the angle between 2 sides to see if it is 90. Just remember 3,4,5.
Measure along the shortest side and mark a measurement that you can divide buy 3 equally. Say it is 12". 12/3 = 4. Now multiply the other 2 sides buy 4, you get 4x4 = 16, and 4x5 = 20. Measure along the other leg of the door and make a mark at 16". The measurement between the 2 points you marked should be 20" if the angle is 90 degrees. If it less than 20" then the angle is less than 90 degrees, if it is greater than 20" then the angle is larger than 90 degrees. 3,4,5 .... 6,8,10 .... 9,12,15 .... 12,16,20 .... does not have to be even but it helps with the math, it could be 7.5,10,12.5, just as long as the ratio is the same 3,4,5.
You can adjust your clamps to correct the angle.
Hope this helps,
MEBCWD is online now
post #4 of 12 (permalink) Old 04-02-2013, 06:29 AM
Hi Nick.
As others said, the first thing is to make sure that your timber is flat and square. The slightest twist will cause the doors to lose alignment and not be square.
Your profile does not show what tools you have. The reason you have doors not "come out quite right", is the reason I have just purchased a jointer.
Sydney, Australia
jw2170 is online now
post #5 of 12 (permalink) Old 04-02-2013, 07:01 AM
First Name: Art
Once you have them glued up check them with a carpenter square and adjust if needed.
mgmine is offline
post #6 of 12 (permalink) Old 04-02-2013, 10:38 AM
First Name: Dick
Hi Nick, no one even mentioned a framing square and corner to corner measurements. I keep a framing square I know is accurate on the bench all the time, That and a dead flat workbench to check for warping. Blum hinges will always have to be adjusted, they are not all set exactly the same from the factory. MLCS has an excellent free door calculator on their website if you are coping and gluing the doors. I just checked the MLCS website it seems I cannot find the free download they are now charging for a CD. That just guarantees Whiteside a more loyal customer and MLCS goes to the bottom of my list!!!!! I have the old free version in Excel XLS format. I need to know from someone if I can post it.
Where there's a Willis there's a way!
Willway is offline
post #7 of 12 (permalink) Old 04-02-2013, 11:27 AM
markm's Avatar
First Name: Mark
Your comments: "Make sure your relative parts are the same length before you try to glue them, height the same, width the same." and "make sure that your timber is flat and square", says it all.
markm is offline
post #8 of 12 (permalink) Old 04-03-2013, 04:41 AM
First Name: Eloy
Howdy from Texas Nick,
I make sure the parts are milled to equal lengths and on entry doors I do the corner to corner measurement then use a clamp from corner to corner to make it square. I have built out feed tables 4' x8' for my table saws and mounted Kreg tracks all the way around periphery. I make sure they are perfectly square when I bolt them up and use the stops to butt up against the rails and styles. I then use the vertical clamps from Kreg to hold them flat then clamp the edges. we can knock out a mess of doors and they are all perfect using this method. Something to think about.
-Eloy
damnitboy is offline
post #9 of 12 (permalink) Old 04-04-2013, 02:03 AM
Country: South Africa
First Name: Gerrie
Hi
I would appreciate it if you can email me with the data. I am making a lot of picture frames and canvasses for my wife.
Regards
Gerrie van Rooyen
South Africa
Gerrievr is offline
post #10 of 12 (permalink) Old 04-04-2013, 06:05 AM
Welcome to the forum, Gerrie. Not sure what data you require.
Search for picture frames in Youtube.
How to Make a Picture Frame Clamping Device - YouTube
Sydney, Australia
Arched doors for base cabinet. papasombre New Member Introductions 9 04-02-2013 02:19 AM
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 32 03-24-2013 03:26 PM
Routing Arch Top Cabinet Doors jreid64 Jigs and Fixtures 8 06-27-2012 07:25 PM
Disassembly of kitchen cabinet doors in order to make them smaller Thelma1 DIY and Renovation 7 01-15-2011 10:37 PM
