Problem with Ryobi R161 router - Router Forums
post #1 of 6 (permalink) Old 07-24-2013, 02:51 PM Thread Starter
bcrobins's Avatar
First Name: Bonnie
Default Problem with Ryobi R161 router
I have a Ryobi R161 (not a plunge router) with RT101 router table. I have used it half a dozen times in accordance with the operating manuals.
The depth adjusting ring has became completely immovable. Clamping lever does move, but adjustment not possible. Is there anything I can do, or am I just our of luck because this is a little inexpensive router, out of warranty? It has done every small job I needed, and is in almost new condition.
I thought maybe I should post to existing R161 thread, but could not find how to do that.
All help appreciated!
Thank you!
bcrobins is offline
post #2 of 6 (permalink) Old 07-24-2013, 08:01 PM
Hi, and welcome to the forum.
I am guessing the adjustment has been clogged up with saw dust. I would remove the router from the table and give it a good blow out and clean out.
Some one else may have had this problem and will offer more solutions.
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 07-24-2013, 08:49 PM
Thank you!
Hi - Welcome to the forum
Just as well you started a new thread, tagging onto an old one sometimes gets confusing, at least to me.
From the looks of the parts explode, that router is very similar to some of the old Craftsman routers and I think James is right on.
I inherited one of the old Craftsman routers from my Dad that was jammed up like that, except that it had sat long enough most all the junk in there was petrified. You can try blowing it out but I needed some, several, applications of WD-40 to soften things up and a lot of time working the plastic adjuster around to free it up. Some automotive brake cleaner may help flush things out also. Advantage of brake cleaner is it doesn't leave a residue so I would recommend using it to flush out any WD-40 or other solvents you may have used. One caution with brake cleaner is that some of them will attack plastic which will give you bigger headaches.
Good Luck
John Schaben
jschaben is offline
post #4 of 6 (permalink) Old 07-25-2013, 06:00 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Go to Ryobi R161 Parts List and Diagram : eReplacementParts.com for the parts schmatic and do a simple breakdown to get to the parts to clean them out. The site also shows the price of replacements (if needed) and those that are discontinued. If the cost of bringing it back to life exceeds the cost of a new one and if you need a new one then buy one, if you have finished all your projects and do not foresee any new projects then hold off until you need one.
Regards - Baker
rwbaker is offline
post #5 of 6 (permalink) Old 07-29-2013, 04:36 PM Thread Starter
bcrobins's Avatar
First Name: Bonnie
This is an excellent forum! Appreciate all the advice I have received. I hope to provide help at some point, rather than needing it, and will certainly post what the cure turns out to be.
Monday is here, but next weekend I hope to work on the problem. I now think that the base just screws onto the motor housing using the spiral track, but of course I can't remove it to clean it because it is stuck. The real mystery is how immovable the needle roller #46 is. I would have thought it would at least rotate a little in its socket. It certainly won't move in or out!
Will at least consult the Ryobi repair shop. At least it is in the same state. Thinking of an oil filter wrench, but with a strong feeling the adjustment ring will break.
Maybe a person with more knowledge than I have could combine this thread with the other one I started when I was blundering around? It is /general-routing/26505-ryobi-depth-adjustment-stuck-new-post.html Wish I hadn't done that. My apologies.
bcrobins is offline
post #6 of 6 (permalink) Old 12-02-2016, 07:57 PM
Skip Whitfield's Avatar
I have a R160 RYOBI Router and cannot keep it running. The spindle lock doesn't seem to completely unlock and after a few seconds of running it slips out of the "partial" position and stops running. Any thoughts?
Skip Whitfield is offline
Ryobi router RE180-1pl depth harvbea New Member Introductions 4 09-29-2012 08:07 AM
problem with ryobi router ert-1150v alwencole New Member Introductions 1 09-08-2012 10:57 AM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
Hi...new to this forum and need some MAJOR help with a router problem Angelo General Routing 14 05-02-2009 11:54 AM
Mounting a Ryobi R175 Plunge Router bobtheengineer Table-mounted Routing 6 01-14-2009 01:34 AM
