small stock small slot - Router Forums
post #1 of 5 (permalink) Old 08-08-2013, 06:27 PM Thread Starter
First Name: Sherwood
Default small stock small slot
Anyone know if there is a good safe way to rout a slot in a small ( 3/4x3/4x2 1/2 piece of stock. I would like it to look nice and don't know if I could get there on the drill press.
drummy is offline
post #2 of 5 (permalink) Old 08-08-2013, 08:27 PM
Gaffboat's Avatar
First Name: Oliver
I would rout the slot in a larger piece and then cut it down to the final 3/4 x 3/4 dimensions. I do that often when I need something small that I know will be hard to work with when it's at final size. It can be done on the drill press with good control if you use something like my drill press sled.
Gaffboat is offline
post #3 of 5 (permalink) Old 08-08-2013, 09:24 PM
I agree with Oliver. I would route the slot on a larger piece of timber and cut to size.
This is very handy if you have to cut more than one.
Use your edge guide or router table if you have one.
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 08-08-2013, 09:55 PM
Honored Member
First Name: pat
Small enough?
Done on my platform morticer.
I would not do this on a drill press or stationary router.
It should be done with the work fixtured and the router in your hands.
Quillman is offline
post #5 of 5 (permalink) Old 08-08-2013, 10:46 PM
Possible to route a 45 degree slot? steambc General Routing 12 08-01-2013 09:42 PM
Routing a small circle on a small board. swartzwalker Portable Routing 10 03-04-2013 07:51 AM
Miter Slot? Denco Table-mounted Routing 15 06-11-2012 11:32 AM
Thin stock to 1/8 inch on Planer ACV Tools and Woodworking 6 10-21-2007 11:13 PM
