Elect prob with Rockwell Unisaw - Router Forums
post #1 of 3 (permalink) Old 09-10-2013, 12:44 PM Thread Starter
First Name: art
Default Elect prob with Rockwell Unisaw
I just got a rockwell 10" 3hp, 220v unisaw from a family member. It didn't start. After testing several of the components. I then used jumper between the power wire and the stop wire on the start/off switch and it ran. I took the switch apart and cleaned the contacts, reinstalled the swithch and it functioned like it should; but now with power to the saw and in the stop position there is humming sound coming from the lvc swithch box. Got any ideas, recommendations.
old macdonald is offline
post #2 of 3 (permalink) Old 09-10-2013, 03:50 PM
kp91's Avatar
First Name: Doug
Does the switch work aside from the hum?
you may have a stuck contact on one pole of your switch, so that the motor is partially energized when 'off'. If it is a capacitor start motor, the centrifugal switch may be bad, but then the motor probably wouldn't start everytime that you pushed the on button, you might have to give it a push.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 3 (permalink) Old 09-10-2013, 05:30 PM
Welcome to the forum, Art.
Electrical problems are outside my realm, but you will get the right advice from the forum.
Sydney, Australia
jw2170 is offline
Unisaw vs. Grizzly Jerry Bowen Tools and Woodworking 71 01-23-2017 02:48 PM
bought a new old Rockwell unisaw stress relief New Member Introductions 13 10-12-2012 12:47 PM
Rockwell 4" Jointer 37-290 knife thickness. rwl7532 Tools and Woodworking 1 01-17-2012 01:10 PM
Saw Delta (Rockwell) 34-461 Unisaw repeters1 DeWalt Manuals 0 06-15-2011 07:47 PM
Unisaw T-slot Dimensions dgleason Tools and Woodworking 7 03-13-2009 09:39 PM
