pressure treated wood - Router Forums
post #1 of 9 (permalink) Old 10-01-2013, 06:26 PM Thread Starter
First Name: Phil
Default pressure treated wood
I bought 2 4x4' s of #2 pressure treated wood today and routered out a 1/2 slot in one side of each to insert two sheets of 1/4 to make a outdoor sign, how long will it take for the 4bys to dry out before I can paint them and is there a way to speed up the drying ?
Chimguy87 is offline
post #2 of 9 (permalink) Old 10-01-2013, 07:25 PM
They should have been dry when you bought them.
post #3 of 9 (permalink) Old 10-02-2013, 12:27 AM
Phil; I'm not sure what Charles was referring to but out here on the West Coast the Hemlock PT lumber HAS to be allowed to drip dry before it's shipped from the treatment plant. I couldn't find a dry piece of PT lumber if my life depended on it; I try and keep some in stock and let it airdry over time, under cover. That way Ihave it when I need it.
The lumberyards try and keep it from drying out in their yards because it has a nasty habit of twisting and/or splitting if it's left in the sun...not a problem from now till April as there isn't any (here)
The short answer then is how is it going to dry this time of the year? If it's indoors (your garage) without heat it could be weeks depending on your relative humidity. If you try and speed up the process (heat) see my first paragraph...bad things will likely happen. On the other hand, it might not be Hemlock, depending on where you are.
Can you just carry on and paint it in the Spring? Or maybe leave it natural?
DaninVan is online now
post #4 of 9 (permalink) Old 10-02-2013, 10:39 AM
Once you get away from the coast it is PT pine or spruce and it is usually pretty dry when you buy it.
post #5 of 9 (permalink) Old 10-02-2013, 10:49 AM
Ahhh, I was wondering about that; thanks for the info, Charles. Certainly would make life simpler.
Having said that, we do get those look-like-log, PT pine peeler core landscape ties that are dry....and rot in a decade (in our wet climate).
post #6 of 9 (permalink) Old 10-02-2013, 11:16 AM
bcfunburst's Avatar
First Name: Reg
Default Pressure Treated Lumber
General rule of thumb is to let the PT lumber alone for one year before trying to paint it. Paint is almost sure to peel if you try to rush the natural aging process. Even after the one year, You need to use a high grade primer if you want your paint to last and adhere. Any cuts you make need to be treated with preservative too @ the time of cutting. Most PT lumber sold in Canada is Hemlock, to my knowledge.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #7 of 9 (permalink) Old 10-02-2013, 12:04 PM
Most of the PT I've bought is pine. Hemlock doesn't get red stain and lots of what I've used had it.
post #8 of 9 (permalink) Old 10-02-2013, 06:32 PM
First Name: Tim
A damp climate cries for Redwood or Cedar. They take oil seals well, so they can then be painted. The chemicals in PT wood, whatever the wood species, make priming, and painting difficult, no matter how dry they get. Spend the extra on the good wood, and the long life of the project will save you lots, both in $$$, and the good will of the customer.
Tim
DrNeon is offline
post #9 of 9 (permalink) Old 10-09-2013, 01:13 PM
bcfunburst's Avatar
First Name: Reg
Amen to that, Tim. It just never works out well when you try to go cheap.
<bcfunburst>
Best Places to buy wood? big wes New Member Introductions 12 01-26-2010 04:34 PM
I need help to choose type of wood dane5547 Wood Species 4 07-25-2009 07:04 PM
