Router bit spacers - Router Forums
post #1 of 5 (permalink) Old 12-18-2013, 11:13 AM Thread Starter
First Name: LP
Default Router bit spacers
Purchased a Freud Tongue & Groove bit (99-036), chart enclosed with the bit indicates spacers range in size from .004" - .039." These spacers are not marked to ID their size, how can I best confirm the size of each spacer? Thanks.....
route712 is offline
post #2 of 5 (permalink) Old 12-18-2013, 11:17 AM
GulfcoastGuy's Avatar
First Name: Patrick
Calipers would be my pick.
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #3 of 5 (permalink) Old 12-18-2013, 08:05 PM
Are the spacers different colors. Sometimes this is an indication of size.
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 12-18-2013, 11:12 PM Thread Starter
First Name: LP
The spacers do vary in color. Would have been easy to list the size for each color on the insert but it's common sense guessing after viewing until I get some calipers. Called Freud this morning (800-472-7307) but the tech wasn't much help as he didn't know what size each color represented. The .039" is black, others are a lighter shade of black and the remainder appear to be a couple shades of grey/silver.
route712 is offline
post #5 of 5 (permalink) Old 12-19-2013, 07:09 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Lay them on a flat piece of glass and visually sort them, now place the to close to call spacers next to each other and run the back of your fingernail over it, the nail will drop if the thickness is less than the one you are comparing it to: repeat until all are finished. A micrometer is better but this is cheaper, faster and it works. With a acid etch pen write the size on the spacers.
Good luck, Baker
rwbaker is offline
Sears Router bit description gary smyth Jigs and Fixtures 4 07-18-2011 12:38 AM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 09:46 AM
