Bench grinder wheel sharpening direction - Router Forums
post #1 of 14 (permalink) Old 02-15-2014, 09:01 PM Thread Starter
First Name: arne
Default Bench grinder wheel sharpening direction
I am setting up a new grinder for sharpening knives and chisels etc. and enquire
Which way the the wheel should be turning .Upward clock wise seems logical as this appears safer.mine is set up so the wheel turns counter clock wise so I thought I would check with the pros.Thanks with your help.
Libra 123
libra123 is offline
post #2 of 14 (permalink) Old 02-15-2014, 09:25 PM
The front face of the wheel should be moving from top to bottom or down.
post #3 of 14 (permalink) Old 02-15-2014, 10:14 PM Thread Starter
First Name: arne
libra123 is offline
post #4 of 14 (permalink) Old 02-16-2014, 05:33 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
They only turn in the correct direction, I have never seen one that ran backwards. N
neville9999 is offline
post #5 of 14 (permalink) Old 02-16-2014, 06:46 AM
Big Steve's Avatar
First Name: Steve
Neville, the all turn the same, but think on it. Depends on which way you look at it and whether the guards are in place.
Mike's answer is correct. Wheel moving down as you face and use it.
I have a similar problem with ceiling fans, which way are they turning?... Looking up at it or from ceiling down!
Steve
Richmond, Virginia
Big Steve is offline
post #6 of 14 (permalink) Old 02-16-2014, 07:11 AM
First Name: Dennis
Steve
I used to have the same problem when I hung drywall. Which way do you run the rotary cutout tool? Is it left or right? Going around inside or outside? We did' thang a lot but every time had a rembering curve.
Dennis
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #7 of 14 (permalink) Old 02-16-2014, 07:16 AM
First Name: George
Your grinder wheel should always turn with the top coming toward you. This allows you to position your part on the tool rest (that should be located at the center point of the grinding wheel) without fear of the wheel taking the part and throwing it at you. A little practice with very lite pressure against the wheel, and you will get it.
wileyboy is offline
post #8 of 14 (permalink) Old 02-16-2014, 07:16 AM
paduke's Avatar
When I started on this Forum "For Me" the most difficult mental task was incorporating rotary logic into my linear trained mind
paduke is offline
post #9 of 14 (permalink) Old 02-16-2014, 07:48 AM
Shortslvs's Avatar
First Name: Fred
I bet if you look closely at your ceiling fan you will see a switch that will cause it to run the other direction. Many do. I hope this does not add to your ceiling fan confusion.
Shortslvs is offline
post #10 of 14 (permalink) Old 02-16-2014, 09:03 PM
Big Steve's Avatar
First Name: Steve
I've got that Fred, but which is for winter and which for summer? Really just an explanation of how your perspective affects an answer.
Steve
Richmond, Virginia
Metabo DS 175 7-Inch Bench Grinder mgmine Tools and Woodworking 1 01-15-2013 10:22 AM
Toycen Tradesman Bench Grinder B52SAC Tool Reviews 7 12-06-2012 02:59 AM
Bench grinder -- difference in 6" & 8" wheel heating object to be ground corbind Tools and Woodworking 13 05-12-2012 06:57 PM
Bench Grinder for sharpening and general use. the202 Tools and Woodworking 7 03-22-2011 06:47 PM
Variable Speed bench grinder?? sourdough Tools and Woodworking 16 09-21-2010 03:35 PM
