recommended router brands? - Router Forums
post #1 of 10 (permalink) Old 02-17-2014, 02:15 PM Thread Starter
First Name: Al
Default recommended router brands?
I currently have 1.75HP Milwaukee variable speed router installed in my homemade router table. I would like to replace the current router and replace it with a fixed base router. There is nothing wrong with the current setup, however, it gets tiresome to remove the router from the table for use outside of the table etc. Are there any brands/models that are recommended? I do some paneled doors which require maybe more hp than 1.75hp. Thanks for responding.
AlMack is offline
post #2 of 10 (permalink) Old 02-17-2014, 03:18 PM
First Name: Don
I just got the Triton 3.25 because of all the good reviews & was on sale for $199. It is not a fixed base but you can do above table adjustments without a lift, it's built in.
Salty Dawg is offline
post #3 of 10 (permalink) Old 02-17-2014, 03:24 PM Thread Starter
First Name: Al
Thanks, where did you buy it? If you have used it, are you satisfied that the unit keep the depth without creep? thanks
AlMack is offline
post #4 of 10 (permalink) Old 02-17-2014, 04:19 PM
kp91's Avatar
First Name: Doug
Al,
All of the big name brands do a pretty good job. I think if you shop for one based on how it feels in your hand you will be doing OK.
Bob J will probably be the best to talk to comparison wise and bang for the buck, since he owns pretty much one of every router ever manufactured.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 10 (permalink) Old 02-17-2014, 05:05 PM
Al, your choice in a new router to be dedicated in your table will depend on how you like to work. I urge you to put dust collection at the top of your requirement list. The Triton TRA-001 that Don suggested is a very good choice for the money. This router allows you to adjust the height and change bits above the table. If you are more comfortable popping your router out of the table to change bits then any of the combo kit routers will do a good job. Most of these are in the 2-1/4 hp range and will handle large bits for the typical home woodworker. The Milwaukee 5625-20 is a real power house with it's 3.5 hp motor and was very popular with local forum members during our big router testing. I suggest you get your hands on any router you are considering buying to try the controls for yourself. While they all do basically the same things they go about it in different ways. Only you can decide which is the right choice for you. My personal favorite router is still the Bosch 1617.
post #6 of 10 (permalink) Old 02-18-2014, 06:19 AM
Shortslvs's Avatar
First Name: Fred
Lots of info out there on the triton. I own two and it is what I have in my table. I have two craftsman, Milwaukee, hitachi... the triton formthe table though.
Check youtube for Trton Table Router and I bet you get enough info to decide. Major plus is above table bit changes without needing a $300 lift. Oh there customer service in US is through Kreg and they Rawk
Shortslvs is offline
post #7 of 10 (permalink) Old 02-25-2014, 09:47 PM
First Name: Phil
I have been using Bosch routers and table for years and have had great luck with them.
Martini is offline
post #8 of 10 (permalink) Old 02-26-2014, 02:13 AM
yup and out work/last the competition...
'nuff said...
post #9 of 10 (permalink) Old 04-19-2014, 10:02 AM
I really like Makita routers because I have found them to be very quiet. I believe all the Makita tools are engineered for low Db. Plus they are super high quality.
papercut is offline
post #10 of 10 (permalink) Old 07-23-2014, 08:13 PM
First Name: Graham
Default Oddly enough
I worked at an indy tool store in the 80's and a makita rep told me that they intentionally made their tools louder because people thought they were more powerful
Graham O
Graham O is offline
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
