Using a cross cut sled - Router Forums
post #1 of 22 (permalink) Old 06-03-2014, 12:47 PM Thread Starter
First Name: Peter
Default Using a cross cut sled
I've built a cross cut sled and I'm wondering how I should use it. I'm cutting fairly small things so I'm a bit nervous about holding things with my fingers. If I don't hold it, then I've found that the things move slightly. Do people tend to clamp things on the sled?
Another thing I've tried is using a push stick, pushing towards the back of the sled, (against my pushing motion). Is this a safe/reasonable thing to do? I use it side on, so it's not hard to reach.
Is there much chance of a kickback? I removed the riving knife when I made the sled.
DrillingThrough is offline
post #2 of 22 (permalink) Old 06-03-2014, 02:32 PM Thread Starter
First Name: Peter
I've managed to keep them steady now. I've been holding them firmer at the start and also having a stop block clamped in place. They don't move now
post #3 of 22 (permalink) Old 06-03-2014, 02:40 PM
JOAT's Avatar
First Name: Theo
I do, I tend to value my body parts.
JOAT is offline
post #4 of 22 (permalink) Old 06-03-2014, 09:19 PM
BrianS's Avatar
First Name: Brian
I would install some type of clamping device for small pieces. Fingers are important IMHO. Is there a reason you removed the riving knife? Using a sled does NOT remove the possibility of kickback occurring.
Brian
(Origin uncertain)
BrianS is offline
post #5 of 22 (permalink) Old 06-03-2014, 10:21 PM
Al B Thayer's Avatar
First Name: Al
Default It's much safer
You may have already found out but all you need to do is hold the piece enough to keep it from moving after its cut. The sled is the safest way to cross cut on the table saw. If I'm cutting super small pieces I use a small stick to hold the piece from moving. Your sled should be made with zero clearence. If its not. mud in the slot with bondo and make a new cut.
Al
Al B Thayer is offline
post #6 of 22 (permalink) Old 06-04-2014, 01:40 AM
Gaffboat's Avatar
First Name: Oliver
I found it easier to cut very small things on a sled I made for my bandsaw.
Gaffboat is offline
post #7 of 22 (permalink) Old 06-04-2014, 06:48 AM
Exclamation clamping...
This is what I did on a recent project.
This would be very easy to copy....
Sydney, Australia
jw2170 is offline
post #8 of 22 (permalink) Old 06-04-2014, 06:52 AM
First Name: Jake
A couple of toggle clamps and you'll be a lot more comfortable cutting small pieces.
Jakexp is offline
post #9 of 22 (permalink) Old 06-04-2014, 07:45 AM
First Name: Don
James,
I really like your sled. Several questions, if I may...Material used for base, size of base, how many runners and made of what? I have seen many versions of a sled and this looks to be the best I have seen. Thanks.....learning and asking....
Don
retired92 is offline
post #10 of 22 (permalink) Old 06-04-2014, 07:48 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Nice Jig James, its the correct answer. N
The other answer is Optus, still it seems to be fixed now. N
neville9999 is online now
Rookie here Raider06 New Member Introductions 8 03-08-2014 05:57 PM
Cross cut sled... jw2170 Tools and Woodworking 14 10-27-2012 09:13 PM
Home Made Cross Cut Jig david cooksey Jigs and Fixtures 2 07-19-2011 01:04 AM
slidng on the rods allthunbs General Routing 11 04-07-2011 05:26 AM
Table saw sled.......... Duane867 Tools and Woodworking 5 07-29-2009 07:59 PM
