Stave accuracy - Router Forums
post #1 of 6 (permalink) Old 06-03-2014, 12:51 PM Thread Starter
First Name: Peter
Default Stave accuracy
I'm making a stave drum and was wondering how accurate they need to be. My staves seem to vary by about 0.3mm end to end (about 7" long).
I was thinking of alternating the staves to reduce the error. ie. +0.3mm on one, and -0.3mm on another which would leave a very small error/gap.
DrillingThrough is offline
post #2 of 6 (permalink) Old 06-03-2014, 06:14 PM
H Peter,
Even though this is a router forum, for a job like that I would use a spokeshave...
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 06-04-2014, 07:26 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Peter you could make a jig that holds your staves at the set angle and they would need to be held rigid with lock down clamps so think about this jig as being a router table sled, rough cut the pieces to get rid of most of the waste as there is no need the make the cutter do all the work, now the jig would hold the pieces at the correct angle and then you slide it past a router cutter on a Router Table and the cutter would trim of anything within its grasp and then leave you with perfect cuts and the router cutter will be vertical so the sled needs to hold the staves at a tilt, no reason this would not work. it would just depend on how many staves you wanted to make, if it was not that many then making the jig would not be worth it. N
neville9999 is offline
post #4 of 6 (permalink) Old 06-04-2014, 09:50 AM
First Name: Gary
How are you cutting them?
gmercer_48083 is offline
post #5 of 6 (permalink) Old 06-04-2014, 02:48 PM
rwl7532's Avatar
First Name: Ralph
The critical stave item is not the length but the angle of each stave.
Am I right that you are concerned with the length of the 7" staves?
Lay the staves out. At this time arrange by how the grain is showing.
Make sure one edge (what will become one of your bearing edges) is all straight.
Now tape them. Once taped, flip the entire assembly over, roll it up and do a check fit.
All joints should appear tight.
Assuming all is tight, unroll and apply glue. Roll it up and secure with band clamps.
Wait 24 hours.
Now sand the one edge of the shell so all is even.
Also it is possible to cut the shell on a table saw.
Now comes the rounding of the outside followed by rounding the inside.
The above describes the steps used for the 5" maple stave snare that I made.
Does this make sense?
After glue- up, you can sand the ends of the shell.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #6 of 6 (permalink) Old 06-04-2014, 06:18 PM
rwl7532's Avatar
First Name: Ralph
Maybe these pics will shed light on what I described.
rwl7532 is offline
How much accuracy can you get from a $249 tablesaw(Ridgid Meets Incra) Glen L Tools and Woodworking 22 12-07-2017 12:26 AM
Accuracy with homemade CNC machine laurent_parti CNC Routing 2 07-31-2013 05:49 AM
Table Top Accuracy heromed Table-mounted Routing 10 12-09-2012 09:35 PM
Jerry's latest Accuracy Test.... Jerry Bowen Tools and Woodworking 25 11-05-2012 07:01 PM
Stave drum turning with a router Tim Brown General Routing 2 10-18-2011 11:45 AM
