Router cutter bearing problems - Router Forums
post #1 of 7 (permalink) Old 06-05-2014, 03:28 PM Thread Starter
First Name: Jeremy
Default Router cutter bearing problems
I have a Gifkins dovetail jig that I have not used very much at all, and today I experienced a repeat of a problem with the bearing below the router cutter head. I have my router securely fixed in a table and today when using the jig, the bearing started to come apart. I think it is just a dust seal that has come away, but I stopped immediately in case it all flew apart. This is the second bearing that has come apart and I am at a loss as to why.
The bearing spun freely and I had previously added a small drop of oil as advised by the jig designer. I run the Triton router at max speed and I wonder if this could be the cause. The jig instructions make no mention of speed.
Can anyone help please.
JeremyB is offline
post #2 of 7 (permalink) Old 06-05-2014, 06:48 PM
Welcome to the forum, Jeremy.
How old are the cutters? I have heard that bearings do not have a long life.
Are the cutters from Gifkins or the very early cutters?
I do not use my cutters very often and in fact have used the bearings on other 1/2" shank cutters.
When I have seen Roger Gifkin using the jigs, he seems to to be running at high speed, so I doubt that is an issue.
You say this is the second bearing, so I am assuming you are using a third party bearing, not the original?
Sydney, Australia
jw2170 is offline
post #3 of 7 (permalink) Old 06-06-2014, 07:26 AM
First Name: Gary
Check for run-out (wobble). Sometimes just cleaning the collet will eliminate run-out.
gmercer_48083 is offline
post #4 of 7 (permalink) Old 06-06-2014, 07:27 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
James is correct and bearings don't last forever, a drop of oil or WD40 type penetrating oil can help still everything has its time to go to heaven and you can get new ones for a few dollars. N
neville9999 is offline
post #5 of 7 (permalink) Old 06-06-2014, 08:27 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
It's all been said.
Harry
harrysin is offline
post #6 of 7 (permalink) Old 06-10-2014, 06:24 AM
First Name: del
i have had the A10 model of the gifkin's for yrs and have made at leat 500 or so box's with dovetales and pin's , so far never had a beiring go bad, if it is the original beiring , i would talk to the person that own's gifkin's, i belive Roger sold the company ? they may give you new beiring's , they don't cost that much, Get a good brand usa made if you can, i use 2 tables and 2 router's , that way it takes less time to make tales and pin's, good luck nice jig
del schisler
port st. lucie, florida
del schisler is offline
post #7 of 7 (permalink) Old 06-10-2014, 06:36 AM
Hi Del,
500 + boxes?....Wow. How did the cutters stand up? Have you had them re-sharpened or replaced?
Sydney, Australia
jw2170 is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Stackable Slot Cutter with top bearing? JDSW Portable Routing 4 06-03-2014 06:46 PM
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
