Dado's Table saw or router? - Router Forums
post #1 of 37 (permalink) Old 07-30-2014, 08:04 PM Thread Starter
Default Dado's Table saw or router?
I'm going to be building a miter saw cabinet and I will be making numerous dado's and I 'm curious when to use a router and when to use the table saw. I have a dado set and an undersized whiteside 3/4 router bit.. Thanks
Mike in Phx is offline
post #2 of 37 (permalink) Old 07-30-2014, 08:16 PM
First Name: Clay
I would use the dado blade since you have one. It is cheaper to use it than to replace router bits. Plus it is sometime easier to get a good fit with todays plywood sizes. IMO
fire65 is offline
post #3 of 37 (permalink) Old 07-30-2014, 09:14 PM
How long does it take to set up the Dado blades? Have you used the Dado set before?
Either one will work.......
Sydney, Australia
jw2170 is online now
post #4 of 37 (permalink) Old 07-30-2014, 09:37 PM
BrianS's Avatar
First Name: Brian
I think it's going to come down to personal choice here... use what you are comfortable with. My personal choice would be the router as it leaves a flat bottomed dadoe. Maybe I've just had poor quality dadoe sets, but the ones I've used have not left a smooth flat bottom. You can purchase router bits that are undersized for todays plywood. But, as Clay suggested, the dadoe blades will stay sharp longer than the router bit will.
Brian
(Origin uncertain)
BrianS is offline
post #5 of 37 (permalink) Old 07-30-2014, 11:07 PM Thread Starter
Thanks. I haven't set up a dado on the T/S yet so I think I'm going to experiment with both and see where I end up.
post #6 of 37 (permalink) Old 07-31-2014, 12:26 AM
TWheels's Avatar
BobandRick, the Router Workshop guys, and the inspiration for the RouterForums some years ago did a comparison and came down on the side of the router. The link is Router Workshop: dado router vrs saw
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 37 (permalink) Old 07-31-2014, 01:03 AM
If you are going to make a bunch of dadoes the same size then it is the dado stack. The good ones do leave flat bottoms. If yo only have a couple or so to do then the router is just as fast or faster. You can dial the width in perfectly with a router bit if you use one that is smaller than the dado you want to make and go with 2 passes. There have been a couple of jigs posted on the forum for that job.
I don't know if you have a shim set for your dado but if you don't I would get one. It's the only way with stacked dadoes to dial in a perfect fit. Veritas® Dado Shims - Lee Valley Tools
I've also heard of plastic playing cards being used.
post #8 of 37 (permalink) Old 07-31-2014, 01:29 AM
There are actually three choices to be made, Mike.
Doing it on the TS, doing it manually with the router, or doing it on a router table.
If I needed to do a rebate or a mortise on a really big piece of lumber or a large sheet of plywood, I'd just lay it on sawhorses and do it with the router and an edge guide. Having said that, I really like using my dado set!
DaninVan is offline
post #9 of 37 (permalink) Old 07-31-2014, 01:37 AM
MAFoElffen's Avatar
Originally Posted by fire65 View Post
I would use the dado blade since you have one. It is cheaper to use it than to replace router bits. Plus it is sometime easier to get a good fit with today's plywood sizes. IMO
Sorry, I was moved by your post and had to comment. I do a lot of dado (grooves) and spline work... ^^^The initial investment is not cheaper.
Someone that has practice with both- The differences between doing dado with a router or a saw is just... well, different.
If I'm doing one or two dado's, I pull out one of my dado jigs and use a router. I use a bit about 75% diameter of the finished size's groove width. You ask why? Because then I can make 2 passes, one each direction of travel, so I can get a snug fit on the groove for the spline joint. It takes less time to setup for a router cut groove than a TS, but the machining takes longer than a dado blade on a TS.
If I'm going to do many grooves, I use my TS. Like I said, It takes just a little longer to set up (not by much time at all). If you haven't set up a stack before... You use different thickness blades and shims together in a stack to get your thickness. After you do it a while, you get a feel for what to do. If not, use a calculator or a chart. Like I said, maybe a bit longer to get the stack together. Machining is a lot quicker than a router. Moving from one to the next cut is quicker...
But doing dado's on a TS assumes that you have a TS with an arbor that can handle the extra width of a dado stack... and the HP to turn it. I have commercial finish quality stacks, as well as commercial standard stacks. I run 4.5 HP w/ 8" and 10" dado's. I would say minimum 1-1/2HP with a 6" dado.
Saying that one is better than the other doesn't wash with me... they are just "different." The width of both can be tailored and tweaked to what you need to do. Someone on a budget can get off cheaper with a router, but it takes longer. Cutting edges eventually wear and need to be sharpened on both, but you get more board feet of cut from a stack. But by the time you figure all the factors in, Dado stacks and the level of TS to drive them is a higher investment.
A low-dollar, usable standard stack can be had for about $50-$70. I'm saying that you can get a stack for about that price that will have a good edge on the sides of the groove, without excessive tear-out... and get a straight cut and even width. That is what is visual in spline joint joining. The quality of the bottom of the groove is not that important until you get to higher end joining.
Besides, the finish quality stacks I have, most people could not afford them and would be prohibitive except for those that really needed them. But for what I do with veneered stock and melamine's, etc... Finish stack and dado scoring (shimmed scoring blades) are a real plus. Which would be a challenge with a router, on the same stock., in the same time and effort.
Not saying that routers don't do a go job, because overall, someone just starting out could, They do a quality job on grooving with a jig. You can get a very quality groove with a router, at nominal costs. One thing you have to take care with is to ensure consistent width of the groove... Then you're golden with that. If not, that will be visual (especially on long grooves, in the joint).
So, yes. There is pluses and drawbacks on both sides. They sort of wash each other out, but basically-- i see my decisions on those being the application and volume.
Next is a question--
Is your Miter Saw a SCMS? If so, then why now do it with that? If it's already set and there, in a pinch, I do up to about 14" long grooves with mine. Gives someone practice in that technique. (Using 1/8" to 1/4" FTG tipped blades)
MAFoElffen is offline
post #10 of 37 (permalink) Old 07-31-2014, 02:12 AM
Funny you should mention that, Mike. Long before I had a TS, I used my radial arm saw with a dado set for almost all my dados and rebates. Never really considered using my SCMS. But I've sure used my builders saw a bazillion times, on framing jobs,
for rebates and (rough) mortises.
DaninVan is offline
Anyone converted a table saw to router table? OneStaple Table-mounted Routing 56 08-27-2019 03:53 PM
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 15 01-26-2015 02:30 AM
Do I need a router plate for my new table? Ryan's Dad Table-mounted Routing 16 09-16-2011 06:53 PM
Router table refurb- Woodpeckers Unilift rstermer Table-mounted Routing 14 11-03-2009 12:21 PM
