Can't unscrew the base of my router, help! - Router Forums
post #1 of 26 (permalink) Old 08-10-2014, 06:18 PM Thread Starter
Country: Argentina
First Name: Pablo
Default Can't unscrew the base of my router, help!
Hi guys, seems like a troll thread but.. it's not :P.
I'm new to routing, I just got a new router and I want to install it in a router table, the model is DW611PK.
The problem I have, is that I can't unscrew the Philips screws that hold the acrylic base to the aluminum body.. they are incredibly strongly screwed there..
I'm afraid the more I try the more the little cross like figure of the screw is going to get more like a little "basin", making it impossible to unscrew.
I didn't try DW40 yet, and I only used a manual screwdriver, not an electric one.
What would you do?, keep trying risking to never being able to unscrew it again?, or any other method?.
Thanks!.
Artemix is offline
post #2 of 26 (permalink) Old 08-10-2014, 06:27 PM
old55's Avatar
First Name: Ross
Welcome to the forum. I'm sure someone with the same unit will help with your inquiries.
Ross,
old55 is offline
post #3 of 26 (permalink) Old 08-10-2014, 06:28 PM
Thanks!.
skip the WD...
add heat (hair dryer/heat gun)...use and impact to tighten a fuzz...
reverse impact and remove the screws...
Stick486 is offline
post #4 of 26 (permalink) Old 08-10-2014, 06:39 PM Thread Starter
Country: Argentina
First Name: Pablo
You mean an impact driver?, do they work better than doing manually?.
Artemix is offline
post #5 of 26 (permalink) Old 08-10-2014, 09:01 PM
First Name: Don
Yes he means impact driver, the hammers inside the driver will loosen the screws up, they do make a hand held driver that you hit with a hammer but don't recommend it for what you are trying to do.
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #6 of 26 (permalink) Old 08-10-2014, 09:09 PM
yes..
Stick486 is offline
post #7 of 26 (permalink) Old 08-10-2014, 09:11 PM
You mean an impact driver?.
do you have one???
Stick486 is offline
post #8 of 26 (permalink) Old 08-10-2014, 11:15 PM Thread Starter
Country: Argentina
First Name: Pablo
do you have one???
No, but since I'm starting with this I was considering buying one.
I was thinking about something like a Dewalt Dcf886, would do the job?.
Artemix is offline
post #9 of 26 (permalink) Old 08-11-2014, 05:42 AM
First Name: Dick
The main thing is make sure the screwdriver or bit is an exact fit to the slots in the screws. Usually bits fit better than a lot of hand held screwdrivers. I would try to find a screwdriver that uses interchangeable bits. They work much better.
Dick
Where there's a Willis there's a way!
Willway is offline
post #10 of 26 (permalink) Old 08-11-2014, 10:35 AM
What they said! They make manual ones as well. I use mine on larger screws than what you're faced with. Not sure how gentle it'd be with the smaller fasteners...
Canadian Tire - Mastercraft 8-piece Impact Driver Set customer reviews - product reviews - read top consumer ratings
7 pc Manual Impact Driver | Princess Auto
Obviously this isn't going to help you in Argentina, but they are available.
DaninVan is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
Dremel Tool Precision Router Base BigJimAK Tools and Woodworking 7 02-08-2010 02:51 AM
