Working with Cork - Router Forums
post #1 of 9 (permalink) Old 08-23-2014, 10:08 PM Thread Starter
tak35bne's Avatar
First Name: Dave
Default Working with Cork
On the fly tying bench I am making I had a thought to adhere cork tiles to the base in order to prevent movement / scratching of tables etc. The question is once the cork is glued in place to the wooden base what is the best way to seal or prevent the cork from cracking or chipping? Is that even possible?
Here is a picture of what I am looking to do.
Dave
tak35bne is offline
post #2 of 9 (permalink) Old 08-23-2014, 10:25 PM
First Name: Clay
No reason you couldn't just roll or spray some poly on it. I would try a test piece first, might darken it a bit.
fire65 is offline
post #3 of 9 (permalink) Old 08-23-2014, 11:02 PM
Dave
Attachment 73264
did the same...1st time I covered 100% of the bottom and used poly...
2nd time only did the corners, centers of each edge and the geometric center of the board... all I had was the drops from the 1st board on hand.. the pieces worked out to be 2.5" square...
sealed it w/ U-40 Cork Seal...
worked out way better the 2nd time...
also tried the stick on sillycone bumpers.. they worked well but the cork lent to so much nicer of a finished board...
post #4 of 9 (permalink) Old 08-24-2014, 06:58 AM
First Name: Richard
Send a message via Skype™ to rwbaker
You might try Cork laminate flooring applied to the base with the cork facing down. Most of these have a clear hard finish infused into the top ~0.5mm. Or you can use regular cork (any other coating might, over time, react with the surface finish) and apply with rubber cement, not contact, so they might be replaced as needed.
Hope this helps,
Baker
rwbaker is offline
post #5 of 9 (permalink) Old 08-24-2014, 08:50 AM
John Bradshaw's Avatar
I don't think you can preserve the cork. Just glue around the edge is my advice, so you won't tear up much when you replace.
John Bradshaw is offline
post #6 of 9 (permalink) Old 08-24-2014, 10:21 AM
Tom in indy's Avatar
First Name: tom
Ditto on the U-40, that is what we use on the cork handles of Custom fishing rods.
helps keep them clean and protected.
Tom in indy is offline
post #7 of 9 (permalink) Old 08-24-2014, 07:26 PM
stanzee's Avatar
First Name: Stan
My thoughts (without experience) on U-40 are: If it makes the surface of the cork hard then it might scratch the table surface the same as if it was wood. If it penetrates the pores of the cork and the feel is as soft as it was before the application then I think that would be the way to go.
Just my thoughts on the subject.
stanzee is offline
post #8 of 9 (permalink) Old 08-24-2014, 09:34 PM
soaks into the cork and the surface tension of the cork stays pliable..
post #9 of 9 (permalink) Old 08-25-2014, 06:52 AM
First Name: tom
There are several different cork sealers.
here is a link to the U-40.
U-40 Cork Seal
Craftsman 315.174921 Not Working TreyC General Routing 17 11-26-2014 08:51 PM
Building a New Router Table-What's the Ideal Working Height? gerrym526 Table-mounted Routing 12 07-19-2014 08:49 PM
What You Must Know Before Working On PCB omnicnc CNC Routing 1 04-25-2012 12:20 PM
My new to wood working experince Weth Starting Off 15 12-02-2011 06:08 AM
You might be a wood working / Router junkie if...... Noddy Lobby 11 08-11-2011 02:17 PM
