PC 4216 DT jig help - Router Forums
post #1 of 6 (permalink) Old 08-31-2014, 08:09 PM Thread Starter
First Name: Gary
Default PC 4216 DT jig help
So I finally bought a dove tail jig. I can cut pins/tails just fine, & they fit tight. But for some reason one corner sits about 1/8 proud of its mate.
The left pin corner is higher than the left tail. The left tail sits higher than the rear pin and so on.
Any thought on what I'm doing wrong?
Satelliteman is offline
post #2 of 6 (permalink) Old 08-31-2014, 08:14 PM
old55's Avatar
First Name: Ross
Gary while I can't help I'm sure a member with more knowledge than I will be along to help with your inquiry.
Ross,
old55 is online now
post #3 of 6 (permalink) Old 08-31-2014, 09:18 PM
Honored Member
First Name: pat
Work is cupped.
Quillman is offline
post #4 of 6 (permalink) Old 08-31-2014, 09:39 PM
I tend to agree with Quillman.
Have you run the timber over the jointer and thickness planer?
Sydney, Australia
jw2170 is online now
post #5 of 6 (permalink) Old 09-01-2014, 02:55 AM
First Name: FoodGroup
If you are talking about half-blind dovetails, I had the same problem when I started with this jig.
The pin board and tail board need to be offset exactly 1/2" to cut a flush joint, but it can be hard to achieve that consistently.
For more accurate alignment, I scribe a line 1/2" from the left edge of the pin board, use the sliding offset guide in the jig to rough-position the boards, then adjust until the scribed line is perfectly flush with the left edge of the tail board.
Hope that helps.
foodgroup is offline
post #6 of 6 (permalink) Old 09-01-2014, 08:09 AM Thread Starter
First Name: Gary
I'd bet you are right. So much for "top choice" lumber from Lowes. I've been practicing with it before using some cherry & maple to make drawers.
Guess I'll have to joint/plane the other pine.
Thanks guys.
Gary
Kelly's New Router Jig Dejure Jigs and Fixtures 1 01-19-2014 12:09 AM
porter cable 4216 jig Da Mrs. Jigs and Fixtures 8 12-14-2011 10:19 AM
