Raised Panel door questions - Router Forums
post #1 of 11 (permalink) Old 11-08-2014, 01:52 PM Thread Starter
First Name: Mark
Default Raised Panel door questions
Hi Guys,
I'm making a set of cabinets, full overlay raised panel doors. I have a couple of questions. I would like my raised panels to be flush on front but not having the groove from the back cutter around the back of door. Should i not use the back cutter and go with 1/2" stock for the panels instead of 3/4 stock to accomplish this?
I'm going to be using 1 - 1/"4 concealed hinges which will give me a 1/4" reveal. Does anyone know what the minimal space between two doors should be, when attaching two doors onto the same rail?
Thanks,
Mark
Mark_M82 is offline
post #2 of 11 (permalink) Old 11-08-2014, 01:59 PM
Originally Posted by Mark_M82 View Post
Hi Guys,
Thanks,
Mark
that back cut is a rabbet and it's function is called a dust lip...
nothing wrong w/ using ½" panels over ¾...
you can find 1/8" panels w/ astragal, stop, casing or some other profiled molding used to simulate raised panel.....
how many degrees of swing are your hinges???
which hinge are you using by make and model # ???
BTW.. your door bit MLCS # isn't a valid #....
post #3 of 11 (permalink) Old 11-08-2014, 02:38 PM
Hey, Mark;
two considerations re the door gaps..
1) you need a bit of room on the hinge side to allow for lateral adjustment once the cabs. are installed.
2) you need a bit of space between doors on the opening sides, as well as a a slightly angled relief on the door edge, to allow for the diagonal width (increasing) which occurs as the door swings open...ie the doors' arcs.
It's a fine line, eh?
DaninVan is online now
post #4 of 11 (permalink) Old 11-08-2014, 02:53 PM
Originally Posted by DaninVan View Post
Hey, Mark;
Dan...
the type, style and the nature of the hinge's swing can change all of that...
post #5 of 11 (permalink) Old 11-08-2014, 05:58 PM
Yes, it can, but why take chances on the fit not working out, to reduce the gap to an extremely small allowance? It certainly won't make it any more aesthetically pleasing.
Doors that don't line up and uneven gaps are what catch the eye (that, and somebody's sloppy ceiling/wall painting booboos; how many times have I seen that on peoples' kitchen/bath cabinetry...)
post #6 of 11 (permalink) Old 11-08-2014, 06:03 PM
I know this...
but OP is looking for the smallest spacing he can get..
his cab...
post #7 of 11 (permalink) Old 11-08-2014, 06:56 PM
I'll throw a number out. I would say that a sixteenth is about right but Dan is correct when he says that an uneven gap will be far more noticeable than a wide gap. Some things tend to catch the eye and others don't. The gap between two doors or one door and it's frame is one that doesn't tend to register that much.
post #8 of 11 (permalink) Old 11-08-2014, 07:02 PM Thread Starter
First Name: Mark
Thanks guys,
Since I'm going with a 1/4" reveal, I was thinking a 1/4" spacing between those doors would look best.
The hinges I was looking at using are Hawthorne & Reid, 1-1/4" Overlay item number HR1071140101 (sorry can't post links yet). Unfortunately they're not showing opening angle. I may have to order the hinges then figure out the spacing.
Mark_M82 is offline
post #9 of 11 (permalink) Old 11-08-2014, 07:21 PM
Semipro's Avatar
First Name: John_*
Is this the hinge you are looking at
Concealed Cabinet Hinge, 1-1/4 inch Overlay
Semipro is online now
post #10 of 11 (permalink) Old 11-08-2014, 08:54 PM Thread Starter
First Name: Mark
John,
Yep those are the ones. Really like the price.
Mark_M82 is offline
Raised panel doors Travisphoto Table-mounted Routing 20 10-11-2014 12:16 PM
Looking for a Raised Panel Bit Set arussell0027 Router Bits - Types and Usage 21 08-11-2014 04:28 AM
Raised Panel Cutters Suitable For House Doors Gaia Router Bits - Types and Usage 2 01-27-2014 02:10 AM
1/2" Stock for Raised Panel rdlorenzo Router Bits - Types and Usage 5 11-19-2010 09:00 AM
help with raised panel bits ccmnova Router Bits - Types and Usage 28 08-19-2010 09:11 PM
