Routing drip channel on cutting board - Router Forums
post #1 of 12 (permalink) Old 11-13-2014, 05:52 AM Thread Starter
First Name: Jeff
Default Routing drip channel on cutting board
I am making multiple cutting boards for Christmas. I have many of them made already. I have a couple of routers but not sure how to cut the channel. Would a guide attached to the router be the best solution? I made them without them but found out most real cooks want a channel. Thanks for any help.
jeffbob is offline
post #2 of 12 (permalink) Old 11-13-2014, 06:12 AM
john60's Avatar
Are the cutting boards all the same size, If so a pattern using a bushing or pattern bit would wok
john60 is offline
post #3 of 12 (permalink) Old 11-14-2014, 07:36 AM
Country: South Africa
First Name: Denis
Default Routing juice channels
As stated by a previous poster this is a ideal pattern routing with a guide bush exercise. I laugh to myself when I read articles showing a 'male' pattern. You are guaranteed to overshoot on the first corner. I use a 'female' pattern and rout in clockwise direction. The router co-operates by pulling in toward the pattern and it is impossible to overshoot the corners. A blind man could rout using this approach.
A problem arises when the cutting boards are different sizes. This is often the case as they are made from offcuts. The answer is an adjustable pattern as shown in my first slide. The rectangular piece of MDF in the centre is a balancing block. The next two slides show how the adjustment 'mechanism' works. The slots were formed by laminating three strips of hardwood. The hardware are standard knock-down bolts and barrel nuts.
The final slides show the result. Of course this only works for rectangular boards.
Denis Lock - "Routing with Denis"
denisl is offline
post #4 of 12 (permalink) Old 11-14-2014, 10:03 AM
That is one beautiful carving board, Denis!
Excellent description as well. Thanks.
DaninVan is offline
post #5 of 12 (permalink) Old 11-14-2014, 10:16 AM
Gaffboat's Avatar
First Name: Oliver
Excellent demonstration, Denis.
Gaffboat is offline
post #6 of 12 (permalink) Old 11-14-2014, 01:38 PM
You are absolutely right Denis. I tried on my first attempt to do it with an edge guide and ruined a cutting board. then made a template like you did for the whole board and succeeded. I like your adjustable jig for holding the cutting board for routing.
Herb Stoops is offline
post #7 of 12 (permalink) Old 11-14-2014, 04:59 PM
MT Stringer's Avatar
I have only done one. I used the set up like Denis did. Especially the support for the inside of the board so the router won't tip.
I used a Core Box bit like this one.
MT Stringer is offline
post #8 of 12 (permalink) Old 11-14-2014, 08:19 PM
First Name: Earl
I bought a Trend Vari-Jig when Sears closed them out for something like $32 or $35 a few years ago. Perfect for this job, works similar to Denis' jig in set-up. (I like the Vari-jig a lot, but i'd not have even tried it at retail--would have made Denis' jig instead. For under $40 shipped--the Trend was a great deal!!)
earl
greenacres2 is offline
post #9 of 12 (permalink) Old 11-14-2014, 11:09 PM
Here is a general representation of the one I use. You take a piece of some spare panel board, osb, mdf, particle board, or ply and attach four strips to it. The strips can be 2x4 or whatever you have as long as they are thicker than your cutting board. In the center will be your cutting board and four spacers the same thickness as your boards. The width of the spacers depends on how far in you want your drip groove to be. If the distance from the center of the router to the edge of the baseplate is 3 inches and you want a 1/2" wide groove 1/2" in from the edge you would want the spacers to be 2 1/4" wide for example.
The cutting board has to be tight in the frame or you will get a wobbly line. You can shim them tight or slot two of the guide rails. In the photo I show two boards with black marks that indicate slots. For multiple boards this would be the best way to go. Snug those two guide rails against your cutting board. The black mark on the end board is there if your cutting boards have a handle. Cut that section out and slide them under.
I purposely left a lot of space between the corners to make a point. Unless that distance is greater that the distance from the center of the bit to the edge of the baseplate it won't make a difference. When you rout the groove you go in a clockwise direction. Unless you are going to make a lot more cutting boards then take this one apart when you are done and save the good parts and burn the rest. It only takes a few minutes to build this jig and it cost virtually no money so why have it take up valuable shop space? Jigs are to get a job done, they are not THE job so it doesn't make sense to spend money on nice wood and brass fittings when you don't need to. Save that money for buying bits and hardware. You can't build those.
post #10 of 12 (permalink) Old 12-03-2014, 01:08 PM
First Name: Denis
Hi Charles
The wood used for my jig was from the scrap box and the hardware was left over from an earlier project and they were certainly not solid brass. I didn't spend any more than you did.
Your jig has one advantage over mine. You can vary the distance of the juice groove from the edge of the board - mine can't.
Your router must have a round base - not one with a flat or two. I would have to add a sub base to my router. I actually don't understand why most of the router manufacturers do what they do to the base. I find it easier to keep a single point on a round base against a guide than to keep a full flat against a guide. Arguments about concentricity don't hold water - I am not going to twist the router through 90 degrees when I am routing. A few degrees doesn't matter even if the router has a base concentricity problem.
denis lock is offline
3/8" slot for cutting board joevm Router Bits - Types and Usage 5 05-13-2014 08:29 PM
Using my router table for the cutting board Gmww Project Plans and How To 9 07-16-2013 08:16 PM
cutting board juice channel Dave845 New Member Introductions 5 03-25-2013 08:03 AM
Inlay in a cutting board dukebeau Table-mounted Routing 1 08-14-2012 03:18 PM
Cutting Board saddlesore General Routing 1 04-30-2007 09:44 PM
