Help with building cabinet - Router Forums
post #1 of 21 (permalink) Old 12-08-2014, 07:55 PM Thread Starter
First Name: Allen
Default Help with building cabinet
I would like some suggestion on what to do with this. It was in my shop when I moved into it and my wife would like me to make it into a cabinet for her to store her sawing supply's in. It is 88 1/2 " tall and 44 1?4" wide. The sides are about 11" deep. There is no top, bottom or back for it. I was thinking of using pocket screws to attach the cross board and the 2 upright boards between the doors together. I was going to use 3/4" birch plywood for the top and bottom and for the back. What would be the best way to attach the top, bottom and back to this? if you see on the pictures with the side is the temp in my shop (32 degrees F) right now so it would be hard to glue anything larger together. I do have a biscuit joiner and routers. I will attach a inside shelf across behind the front cross board and all the rest of the shelf's I would like to make adjustable and have a shelf bin gauge tool to do that. Any help would be much appreciated.
Allen
firstmuller is offline
post #2 of 21 (permalink) Old 12-08-2014, 08:27 PM
Allen
repair the front...
rabbet and dado everything that you can...
1/2" ply for the back...
in addition to the pocket screws.. face screw when ever possible..
as for glue... make a drop cloth tent w/ a small electric heater for the glue ups...
post #3 of 21 (permalink) Old 12-08-2014, 09:33 PM
MT Stringer's Avatar
Well, you know what you need. Actually, it sounds like it would be fun to put that thing back together.
1/2 inch birch for the back.
Like Stick said, use dadoes, or pocket screws if they won't be seen.
I would get the measurements off of the front and rebuild the cabinet to fit. Maybe make it a tad less than the width of the front. You can come back later and cut the side flush to the front frame.
Good luck. Post some pics. I like pics.
MT Stringer is online now
post #4 of 21 (permalink) Old 12-09-2014, 12:51 AM
I guess if I suggested the fireplace, I'd be in the minority?
It looks like old-from-the-lumberyard D. Fir, with knots at that.
Sorry; hate to be a party poop but it's just an old softwood relic.
Too many times I've tried to make a purse out of a pig's ear...it was still a pig's ear.
No criticism intended; just being realistic.
DaninVan is online now
post #5 of 21 (permalink) Old 12-09-2014, 04:52 AM
First Name: Mark
Default use the best parts
I would cut up the best parts and make what you can per the sizes left.
MLH Services is offline
post #6 of 21 (permalink) Old 12-09-2014, 11:35 AM
First I would measure where I would be putting it. Remember you will have to put a base on it. Deduct the height of the base and then you have the size of the cabinet box you need to build.
Next build a cabinet box that size , with a top, bottom ,back and a middle shelf all dadoed in. Then carefully take apart the face frame,clean them up and sand off the old finish and cut dadoes/rabits into the face frame to fit the box you just made. If the new box is shorter than the existing face frame, you can rip down the middle cross piece to shorten the overall height, Then fit the doors,sand and finish, reinstall the hardware and build a base to set it on. Looks Like you have some extra material standing up there to use if needed.
You may want to start with new material and just build a new cabinet, it is going to be more work to save this one, but if it has some sort of nostalgic value then go for it.
But get some heat in there , it is hard to work in the cold. Good luck.
Herb Stoops is online now
post #7 of 21 (permalink) Old 12-09-2014, 12:52 PM
"You may want to start with new material and just build a new cabinet, it is going to be more work to save this one,..."
Phew! I thought I was a voice in the wilderness.
post #8 of 21 (permalink) Old 12-09-2014, 01:29 PM
I would probably just use 3/4 x 3/4 strips of wood in the corners and to lay the base onto and to hold up the top. Cross screw through them into the sides and into the back side of the front. You could go back and glue them later when it warms up if needed. As pointed out it probably isn't worth putting a lot of time or effort into.
post #9 of 21 (permalink) Old 12-09-2014, 01:47 PM
YOU CAN'T BE SERIOUS!!!!
there's art in that cabinet..
repaired and oiled and his wife will have what she wants...
I see the merit too...
post #10 of 21 (permalink) Old 12-09-2014, 02:06 PM
If you look around, there should be a lot of images on Google where folks have re-purposed old stuff. Some even beat 'em up even more. Especially, if your lady wants it painted. I think this would be an ideal candidate to rebuild, beat up the new stuff, paint it white, then paint it a color of choice. Then sand through some of the top coat to reveal the white below it.
There are examples of how to do it on You Tube and elsewhere.
Put some clear on it and set it for all to see.
How to Faux-Age Painted Wood Furniture | This Old House
How to Paint Wood Furniture With an Aged Look : How-To : DIY Network
How to Distress Furniture | Easy Crafts and Homemade Decorating & Gift Ideas | HGTV
And on, and on...
Building a cabinet for a table saw jaydubya Tools and Woodworking 7 12-30-2012 12:25 AM
Cabinet building questions Brett K Starting Off 5 12-21-2012 10:16 AM
Need Cabinet Building Guidance for my Workshop Lonely Raven Starting Off 16 11-20-2012 10:53 AM
building a cabinet for router table tksigler Table-mounted Routing 10 02-28-2010 10:53 PM
Building a A/V Cabinet - Need some advice ross.anderson Tools and Woodworking 4 01-09-2010 12:10 PM
