Advice on criss cross pattern - Router Forums
post #1 of 14 (permalink) Old 02-08-2015, 10:42 PM Thread Starter
First Name: Jamie
Default Advice on criss cross pattern
I am making a game board that involves multiple criss crossing dado cuts as pictured below. I made a simple edge type jig which runs in the dadoes for my router so that they will be perfectly equidistant. Before I use it on the rosewood, I tried it on some scrap pine and had a lot of chip out at the dado crosses. I was using a 3/16" straight cutter at a depth of 1/8" for 3 passes. Any suggestions?
jemangin is offline
post #2 of 14 (permalink) Old 02-09-2015, 12:07 AM
Semipro's Avatar
First Name: John_*
Jamie
Trying doing all the cross grain cuts first
Semipro is online now
post #3 of 14 (permalink) Old 02-09-2015, 06:08 AM
Country: South Africa
First Name: Denis
Jamie
Pine is very susceptible to chipping. Follow John's advice of doing the cross-grain cuts first on a scrap of hardwood.
Denis Lock "Routing with Denis"
denis lock is offline
post #4 of 14 (permalink) Old 02-09-2015, 06:24 AM
make all your cross grain cuts 1st...
change to a best quality up spiral bit...
post #5 of 14 (permalink) Old 02-09-2015, 07:08 AM
DonkeyHody's Avatar
First Name: Andy
Jamie,
I know this might sound like heresy on a router forum, but I would use a table saw and dado blade to make those cuts. Much less tear out.
ďWe should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore.Ē - Mark Twain
DonkeyHody is offline
post #6 of 14 (permalink) Old 02-09-2015, 08:11 AM
First Name: Dennis
Jamie
I don't know what game that is but it looks pretty cool! Use a table saw and make the cuts rather slowly.
Dennis
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #7 of 14 (permalink) Old 02-09-2015, 09:27 AM
First Name: Dennis
For any of my inlay work I use downcut spiral bits which will eliminate any tearout even on veneers that have a very thin surface skin.
Dennis
routergieck is offline
post #8 of 14 (permalink) Old 02-09-2015, 11:40 AM
Jamie; forget about the tearouts, more about the GAME!
How is it played?
How many people can play (I'm guessing two)?
Your picture is pretty clear on the construction, but are there plans somewhere?
DaninVan is online now
post #9 of 14 (permalink) Old 02-09-2015, 11:51 AM
RainMan 2.0's Avatar
I'm liking the table saw , dado idea the best .Guys was wondering if a sacrificial piece of mdf could be placed under it so there's no tear out . Dumb idea?
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 14 (permalink) Old 02-09-2015, 01:21 PM Thread Starter
First Name: Jamie
Thanks for the great advice. I have to cut about 4" of the split end off of my board so I will do a bit of experimenting with a spiral bit and my dado blade and see which turns out best.
The game is Quoridor. French origin, I think. Kind of like checkers except you can place a blocking wall or move your man on your turn. Your opponent then has to go around the wall. Can be played with two to four players(each person takes a side of the board and heads for the opposite side). No plans. I found this picture online and decided to try and reproduce it.
jemangin is offline
Cross Cuts Differ From Rip Cuts... Jerry Bowen Tools and Woodworking 9 07-15-2013 11:27 AM
Plunge Pattern Bits? Doctor Atomo Router Bits - Types and Usage 4 04-09-2012 04:52 PM
Making Exact Part from Pattern JayMc General Routing 3 02-09-2012 02:57 PM
Need advice for pattern holding & safety Elrod Jigs and Fixtures 19 03-26-2011 04:29 AM
Advice needed for spiral & pattern bits please cagenuts Router Bits - Types and Usage 4 05-10-2010 02:20 AM
