First router project - Router Forums
post #1 of 17 (permalink) Old 02-26-2015, 06:23 PM Thread Starter
First Name: Ted
Default First router project
Hi all - new here, with some first post questions about using a router, and a few more for my first router based project!
My new router is a Bosch 1617 kit. The project will be be replacing a 5 foot section of stair rail! The new one will be in Craftsman style, so about 30 or so mortise and tenon joints, all doing various joins on the 2x2 balusters. Wood will be clear pine (!) (Sorry, but have to match all the other wood in the house!)
After playing around a lot for the first time yesterday, I finally got various thicknesses of scrap wood clamped together to make a fence, so I could route down the centerline of a 2x2. What is the diameter of the Bosch router base? Is it metric? It does not seem to be any convenient size! Anyway, this led to ordering the official edge guide, which should arrive tomorrow. Hope that eases some of the pain....
Mortise and tenons will end up being 1/2" wide x 1" long, undecided how deep - 1/2" or maybe 3/4".
Second, not wanting to spend $70 on an up spiral bit right away, I got a 1/2" straight one at Lowes for playing with. How do I judge what speed to use? There was a bit of wood burning - too fast? Too much pressure? While I would rather not have to get the pricey bit for now, should I (given the number of cuts and the wood being cut)? I expect to later, but am trying to space out the purchases a bit...
The project will also require a 5 foot 2x2 sub-rail with mortises running the length, spaced about every 8". Any suggestions on how to make a start/stop jig so I can maintain accurate spacing and mortise length? Sighting where the bit will hit the wood to get an accurate mortise start when doing a plunge seems a little challenging.....
Finally, a glue question - Titebond or Gorilla? I'm thinking Gorilla, as it will help fill joint gaps (as long as I am careful so it doesn't expand out to the surface or push things apart!) But if you think caution is in order for this project, please advise and I'll go with the more conventional wood glue.
Thanks for any and all advice in advance!
sande005 is offline
post #2 of 17 (permalink) Old 02-26-2015, 06:27 PM
old55's Avatar
First Name: Ross
Welcome to the forum Ted.
Ross,
old55 is offline
post #3 of 17 (permalink) Old 02-26-2015, 07:12 PM
1st off I'd like to send you to my uploads...
PDF's aplenty on jigs, speeds, methods, using a router and some nonsense
http://www.routerforums.com/profile....1&showthumbs=1
are you plowing the 2x2 (making a dado)???
6'' SAE...
Is it metric?
no...
it will...
can you be a bit more descriptive as to what you are doing???
are you making a banister???
max..
WTB you are biting off more than the bit can chew..
skip the gorilla and go w/ the tite bond
post #4 of 17 (permalink) Old 02-26-2015, 08:16 PM
Nickp's Avatar
First Name: Nick
Ted...maybe the bit you have will not "dig in" meaning, no cutters on the business end for drilling straight down...AND...the dust is not clearing while you are trying to hollow out the mortise...?
As Stick mentioned, try doing a little at a time and clear the sawdust then go deeper...
Good luck and welcome...Nick
Nick
Nickp is online now
post #5 of 17 (permalink) Old 02-26-2015, 08:45 PM
I got this sneaky feeling he's trying to make a deep dadoes in a handrail for spindles...
post #6 of 17 (permalink) Old 02-26-2015, 09:57 PM
look at this PDF and see if anything is like what you are trying to do...
post #7 of 17 (permalink) Old 02-26-2015, 10:03 PM Thread Starter
First Name: Ted
Sorry, using wrong terminology.....
Yes, Stick guessed correctly. I'm drilling in and then moving forward, not starting from an edge.
Test mortises are 1/2" deep, I started by using the step adjustment, and recut one step at a time, rather than going full depth all at once. Bit seems to have cutting edges on the end, so while not like a full on drill, it is cutting when plunging. Yes, it may be plugging with dust. Guess it will be a trip to Rockler tomorrow.... In any event, it is hard to recut deeper in subsequent passes and stay exactly in the preceding track. Again, maybe the edge guide will rescue me.
As far as base size - the plunge base seems to be about a 6 5/8" circle diameter, with one edge cut off, hence the issue with making a fence. Hard to describe how I was holding it. Let's try: If the router is moving directly away from me, I was holding the handles on the right and left sides and pushing away. Should they instead be in line with the track the bit makes, and the cut off edge of the plunge base against the homemade fence?
Thanks for the link to more info!
sande005 is offline
post #8 of 17 (permalink) Old 02-26-2015, 11:07 PM
okay...
test for what???
1/8' cuts/passes are fine as in very good...
understood..
pine is a wood that has it's own quirks.. I believe that the bit is loading up w/sap/gum and may be your issue...
for sap.. mineral spirits and a tooth brush will clean that bit up right fine..
see the PDF's..
clean the bit a try again before you leave
I like my Freud bits... Whiteside are good ones too... pleases do yourself a favor and leave the Asian imports at the store...
and up spiral would be the ticket but there's nothing wrong with a straight bit.....
see the PDF's..
to do a really accurate cut you'll need two guides
one on each side of the rail so that the rail runs between the guides...
use the Bosch guide on one side and a home made one for the other...
that's the norm for a plunge base...
handle position is for your comfort...
if your single guide is on the left side of the rail (rail pointed away from you) you pull the router to you..
if the guide is on the right you push the router away from you..
now tell us what it is you are trying to do exactly...
what type of spindles are you installing and why are you dadoing so deep..
yur welcome...
File Type: pdf Care and Sharpening of Router Bits.pdf (123.5 KB, 39 views)
post #9 of 17 (permalink) Old 02-27-2015, 12:00 AM
Hi Ted and welcome. You will find the routing much easier and your bit will last much longer if you remove some of the wood first with other tools. If you are making a continuous groove then set a skillsaw for the right depth and make at least one cut with it. You'll have to try it to believe what a difference that can make. If you are making individual mortises for each spindle then drill some holes and try to remove at least 50% of the wood that way. The router bit then is mostly cleaning up what's left. Because the bit gets some air to cool with and has room to get rid of the chips it will run much cooler.
What Stick says about the edge guide is correct. It will keep from going in farther but it won't stop the router from coming back the other way and without the second fence on it, it will.
About the foam that polyurethane glues produce: according to the manufacturers' websites (all of them I've seen), the foam has no strength. Joints must be tight fitting for the glue to hold. If you want a glue that will fill gaps you need a thick epoxy or a glue with high solids content like Lee Valley's 202GF. However, if you have a tight fitting joint it isn't always a good idea to use a gap filling glue. They might cause the joint to split.
post #10 of 17 (permalink) Old 02-27-2015, 07:29 AM Thread Starter
First Name: Ted
Thanks all!
Had a chance to review the pdf's Stick referred me to. The first jig looks like just the ticket! A little bit of modification, so I can also get the spindle spacing, and I should be good to go. May not even need the Bosch edge guide!
The project:
This is replacing a level railing section. Hope to reuse existing end newels, but will replace if I have to.
Attached is a picture that is close to what I will be doing.
Spindles (balusters) will be 2x2's. I will be cutting tenons in each of the spindle ends, to fit in mortises on each horizontal element. Using my dado saw, it currently looks like a tenon that is 1/2" wide, by 1" long, by 1/2" tall coming off of the 2x2 end would be about right. Hence the slots cut by the router will be 1 (l) x 1/2 (w) x 1/2 (d). Slots in the horizontal run will be a little over 4" apart, meaning the spindles will be about 4" on center. The slots are only 1/2" deep. Maybe I'll go to 3/4 inch deep if after playing some more I think I need the added wood surface.
I had originally thought to do all this using dowels, but M&T seemed more elegant. After getting a quote from a local carpenter, it fully justified my completing my tool set and getting a dado blade and a router! So this is my first foray into woodworking that is closer to cabinetry than deck building or replacing interior mouldings done previously.
So far, I've only been doing test cuts in scrap to get a feel for how the router operates. Will do a bunch more, and some mock-ups of the railing before I go for real. The good side of pine - it's cheap, so I can waste a lot of it!
sande005 is offline
Router project for 2010 hilltopper46 Show N' Tell 12 07-21-2010 11:42 AM
