Questions about leveling a work table - Router Forums
 5Likes
post #1 of 15 (permalink) Old 03-21-2015, 12:43 PM Thread Starter
First Name: Eugene
Default Questions about leveling a work table
I am continuing to build a workshop in my 2 car garage, the floor slopes in the garage like most garages. My table saw is a rigid 4512 that is mobile, when it's sitting flat on its legs it's slopes, I can put shims on it and it's pretty level from back to front, I just built a mobile table that will be used mostly a a outfeed table. It has 4 3inch casters that don't adjust up and down just lock the wheels, shouldn't I worry about having a level top to the outfeed table or just leave it be, I tend to move my ts around because the garage is limited on space until it warns up and I can put up a shead, that's for any input..
Eugd is offline
post #2 of 15 (permalink) Old 03-21-2015, 01:31 PM
Eugd; I feel your pain! I'm also dealing with the same issue (Dewalt Contractor Saw).
I put mine on a mobile base, which has height adjustable castors.
Unfortunately I didn't fully think it through...
I put the pedal which lifts it onto the castors off to the side so it wouldn't be sticking out when I'm in front of the saw. Wrong. The back two are non adjustable so in effect I created an additional problem.
Next time my son-in-law is visiting we're lifting that sucker up and turning it 90 degrees! (he doesn't know yet. It's heavy)
Similar to this:
https://www.kmstools.com/general-int...obile-base-322
DaninVan is offline
post #3 of 15 (permalink) Old 03-21-2015, 02:38 PM Thread Starter
First Name: Eugene
I'm thinking about having it parallel to the floor and if I'm something the work peice should still be level to the floor, even though it's pitched, I was thinking about turning it 90 degrees also but then one side of the saw would be higher than other, I am starting to feel that as long as the saw and the outfeed table are on the same pitch that should not sacrifice the quality of the cut? Or am I just talking my self into believing that?
Eugd is offline
post #4 of 15 (permalink) Old 03-21-2015, 02:42 PM
RainMan 2.0's Avatar
Im thinking linear actuators ,gyros and a closed loop feed back system
jw2170 and MT Stringer like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 15 (permalink) Old 03-21-2015, 03:00 PM
Nickp's Avatar
First Name: Nick
Probably more important is that the saw cutting is not perpendicular to the pitch...this would make the piece try to slide towards the pitch. If you set it up so that the cutting pitches parallel to the floor the piece will go "downhill" with the pitch. Anything else would make you adjust your outfeed and the saw whenever you use it but not in EXACTLY the same spot...
Welcome...you'll like it here...
Nick
Nickp is online now
post #6 of 15 (permalink) Old 03-21-2015, 03:04 PM
Nickp's Avatar
First Name: Nick
...don't forget WAAS-augmented GPS or digital geo-ballistic weapons-grade location device to automatically adjust for variances in location in the garage.
Got milk...?
MT Stringer and RainMan 2.0 like this.
Nick
Nickp is online now
post #7 of 15 (permalink) Old 03-21-2015, 03:38 PM
Eugd if everything slopes the same then there is no problem. If one twists compared to the other there will be a point where the outfeed table could contribute to the possibility of a kick back. What if you built a mobile base that held the saw and the outfeed table and put that on casters? If you happen to be tall like I am that would be a bonus having everything a few inches higher.
post #8 of 15 (permalink) Old 03-21-2015, 05:56 PM
I was thinking the same thing regarding the slope Charles , as long as there on a slab with the same slope it should be fine .
I have to say when the outfield table doesn't line up right it's gotta be the biggest pita that I've encountered . Dangerous too
post #9 of 15 (permalink) Old 03-21-2015, 06:17 PM
I posted a comment here a while back on this topic. Faster to recap than go looking for it...
In my situation, I want all the bench-tops at or lower than the final elevation of the TS.
If the saw is moved to either side nothing changes elevation wise; it's only if I roll it in or out that it changes the relative ht. to the bench-tops and outfeed table.
I'm using the same method that I did with kitchens. Level all the bases first, then place the cabinets onto them. Yes there will be a falloff from the back of the garage to the front...maybe 2"+/- ? But at least all the box carcases will have the same size gables. The outfeed table will have inserts in the leg bottoms with machine bolts for leveling.
(That's actually what I have now, but I want to redo the whole shebang because the outfeed is being used for everything.
The critical factor is that it all starts with the TS sitting dead level on its mobile base, in its working location. An el cheapo laser leveling device will project that elevation onto the wall and anything else that's related. .
DaninVan is offline
post #10 of 15 (permalink) Old 03-21-2015, 06:30 PM
just do it right from the get go and self level grout/resurface the floor....
one day to the end of issues and fiddling...
do it in segments if need be...
Self Leveling Concrete | Duraamen
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 10:30 AM
Rockler and Benchdog table inserts, also install questions Duane Bledsoe Table-mounted Routing 2 02-03-2015 06:25 PM
Router Table To Fit On Work Mate Gaia Project Plans and How To 16 07-14-2013 06:51 PM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 09:51 AM
A few router table questions. archer_456 Table-mounted Routing 17 03-21-2005 11:30 AM
