Plywood lift and tilt - Router Forums
 5Likes
  • 3 Post By vindaloo
  • 1 Post By todd628
  • 1 Post By chessnut2
post #1 of 10 (permalink) Old 04-25-2015, 02:47 PM Thread Starter
First Name: Larry
Question Plywood lift and tilt
As a newbie, browsing thru the site I saw pictures of a neat device to help get full sheets of plywood into place for cutting. It was made from some 2x4s with wheels. By loading the sheet on edge, it could then be tilted to a horizontal position.
Now that I want to take a closer look, I can't find it again.
I recall it some where in the middle of a discussion on another topic
Can some one tell me where to find it?
LBoyd is offline
post #2 of 10 (permalink) Old 04-25-2015, 03:17 PM
vindaloo's Avatar
First Name: Angie
Is this the one you mean?
http://www.routerforums.com/show-n-t...good-cart.html
ksidwy, Geevesmac and jj777746 like this.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #3 of 10 (permalink) Old 04-25-2015, 07:10 PM
Welcome to the forum, Larry.
Sydney, Australia
jw2170 is online now
post #4 of 10 (permalink) Old 04-25-2015, 08:00 PM
jj777746's Avatar
Originally Posted by vindaloo View Post
That's the one I thought he wanted also."sheet good cart" or "good sheet cart"made by Todd. The wording stuck in my mind
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #5 of 10 (permalink) Old 04-25-2015, 08:32 PM
todd628's Avatar
First Name: Todd
Are you guys making fun of my wording? I'm goona take my toys and go home.
Actually I hope the cart will be of value to you. I really like mine, I love being able to put the sheet goods on the cart and tip it up to load the tablesaw.
Have a blessed weekend, Todd
JamesLybarger likes this.
todd628 is offline
post #6 of 10 (permalink) Old 04-25-2015, 09:52 PM
old55's Avatar
First Name: Ross
Welcome to the forum Larry.
Ross,
old55 is online now
post #7 of 10 (permalink) Old 04-26-2015, 06:43 AM Thread Starter
First Name: Larry
Thank you, that is what I was looking for. Thank you Todd, mine won't look as fancy as yours but will hopefuly be as useful
LBoyd is offline
post #8 of 10 (permalink) Old 04-26-2015, 07:54 AM
todd628's Avatar
First Name: Todd
Larry,
I am changing the 2 main beams of the tilting top along with the sheet goods supports.
Those supports are joined with box joints. That joint has proven to be a week spot. So I am changing those two pieces to be made from Oak. I may also make those pieces a full 2" thick.
If you don't have a good way to make the box joints you could use 1/2" thick pieces laminated together to make up that corner finger joint.
I must say it was my fault, for that joint failing I had 20 sheets on the cart already and said it would handle 2 more. You might say that was the straw that broke the Camels back.
Other than creating that problem the cart has worked wonderfully.
Have a blessed Sunday and some fun making dust, Todd
todd628 is offline
post #9 of 10 (permalink) Old 04-26-2015, 09:37 AM
chessnut2's Avatar
Welcome to the forum, Larry. I'm glad you were able to find the one you're looking for. I've had the same problem with not being able to find good ideas that were mentioned in posts, because usually the thread has a different name.
I had to put a folder on my desktop, and whenever I see something I want to keep, I go ahead and make a shortcut to the post, name it something I'll recognize, and place it in that folder. As you can imagine, all the good ideas in this forum have made for a pretty big folder, but at least I can find an item when I need it.
ksidwy likes this.
chessnut2 is offline
post #10 of 10 (permalink) Old 04-26-2015, 08:26 PM
First Name: Allen
The WOOD magazine March 2012 had plans for a fold flat sheet goods mover to be make from 1 sheet of 3/4" plywood.
Allen
firstmuller is offline
Router Lift Casadia Table-mounted Routing 20 02-15-2015 08:22 AM
