Harry Burrs on My Gears - Router Forums
 19Likes
post #1 of 25 (permalink) Old 05-31-2015, 10:59 PM Thread Starter
Billy Hill's Avatar
First Name: Will
Default Harry Burrs on My Gears
Material is poplar, I'm using a 1/16" carbide 2 flute spiral flute end mill (the kind used for cutting alum). All the edges have harry little burrs that look like they will be a pain to remove. This is after I sanded it lightly with fine paper.
Name:	harry gears81200.jpg
Instead of seeing things and asking "why", envision things and ask "why not"
Billy Hill is offline
post #2 of 25 (permalink) Old 05-31-2015, 11:09 PM
bit is dull...
Stick486 is offline
post #3 of 25 (permalink) Old 05-31-2015, 11:11 PM Thread Starter
Billy Hill's Avatar
First Name: Will
Yes. That's the foresight solution. I need the afterthought solution.
post #4 of 25 (permalink) Old 05-31-2015, 11:17 PM
or it's flutes are sap loaded...
use a better quality bit..
use a differently rated cutter...
dental burrs perhaps...
Stick486 is offline
post #5 of 25 (permalink) Old 05-31-2015, 11:39 PM
Will, End mills are not designed to cut wood. Many people use them trying to save money. Do yourself a big favor and look here for the bits you need:
Whiteside Machine Company
DesertRatTom likes this.
post #6 of 25 (permalink) Old 05-31-2015, 11:53 PM
I think the smallest dia he's going to find is 1/8''..
a down spiral would be a plus...
so less than 1/8'' leaves burrs..
Tungsten Carbide Lab Cutters
and wait till Harry finds out he's got burs..
swarfmaker likes this.
Stick486 is offline
post #7 of 25 (permalink) Old 06-01-2015, 12:29 AM Thread Starter
Billy Hill's Avatar
First Name: Will
I wouldn't have thought burrs would work well in wood, but if they do (and don't leave burrs) I'll give them a try. I've used them to cut graphite and have a few bigger ones I could try but nothing small enough for what I'm trying to do currently.
Not sure about the 10 pc minimum on that site but considering the end mills I have currently cost between $20 and $40 ea, seeing these burrs for < $2.00 ea makes it easy to buy 10 even if I don't know if they'll work.
That being said, and back on topic, what are my options to remove the burrs on this part (since it's too late to buy new cutters). I could probably bead blast it but I'm afraid it will make it look bad when I finish it.
Maybe blasting it with compressed air and rubbing it with blue-jean rags will take them off without breaking off any more of the gear teeth.
post #8 of 25 (permalink) Old 06-01-2015, 03:10 AM
Semipro's Avatar
First Name: John_*
Sorry Will
I see your problem no easy fix maybe Dremel type tool with sanding sleeve no easy way time and hand repair
Semipro is offline
post #9 of 25 (permalink) Old 06-01-2015, 06:50 AM
Nickp's Avatar
First Name: Nick
I would use some fine sandpaper rolled to the appropriate size and lightly sand at an angle (top down based on your picture). Yes it might leave a slight rounding on the edge...canvas cloth might be better...
Billy Hill likes this.
Nick
Nickp is offline
post #10 of 25 (permalink) Old 06-01-2015, 08:14 AM
First Name: Gary
Will, My first thought for the fuzzy gear edges are miniature files or a well honed small hand chisel. For the relief areas that are flat, a scraper modified to fit in between the gears would work quite well to smooth out the router marks. To me power tools are not always the answer. Besides that the hand work is quiet, relaxing, gratifying and without all the airborne dust. Often in antique carvings I have seen stippeling done with a punch that has a design filed into the end of the punch and when repeated all over the depressed areas makes the project look quite unique and gets rid of the machining strokes left by your router.
gmercer_48083 is offline
Joke a Day bobj3 Lobby 3932 Today 01:36 AM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
Thanks Harry jw2170 Lobby 15 10-28-2010 02:28 PM
