Modifying Newell posts - Router Forums
 2Likes
post #1 of 16 (permalink) Old 06-26-2015, 05:58 AM Thread Starter
Knothead47's Avatar
Default Modifying Newell posts
I'm doing some remodeling and had to cut one of the Newell posts on the stairway since it was nailed to the step. Now...my problem is that I will need to cut both Newell posts to have the same length. I'm considering doing something fancy/decorative on the bases to make up for the lost length. Your suggestions are most welcome. Thanks!
John T.
Knothead47 is offline
post #2 of 16 (permalink) Old 06-26-2015, 06:28 AM
how do you intend to mount the posts???...
post #3 of 16 (permalink) Old 06-26-2015, 05:09 PM Thread Starter
Knothead47's Avatar
Good question, stick486! I was considering using picket screws with stained plugs to match. Or put some sort of base with contrasting white paint to match the balusters. The Newell posts and rails are a dark stain. The original installation was a couple of nails driven at an angle. The top post that I cut was against a wall and was also glued to the sheetrock! After what little remodeling I have done, I can understand a friend who refuses to do any remodel jobs. He says all you do is correct someone else's mistakes.
Let me describe, which I should have done in the beginning: the house is a split foyer. There are two Newell posts in the LR;One post is a half-Newell and I'll bet it is glued to the sheetrock. The other two are on the first set of steps down to the foyer. I could tape and paint the other post bases to match. Thanks!
I quit drinking too early!
John T.
post #4 of 16 (permalink) Old 06-26-2015, 05:43 PM
Originally Posted by Knothead47 View Post
Good question, stick486! I was considering using picket screws with stained plugs to match. Or put some sort of base with contrasting white paint to match the balusters. The Newel posts and rails are a dark stain. The original installation was a couple of nails driven at an angle. The top post that I cut was against a wall and was also glued to the sheetrock! After what little remodeling I have done, I can understand a friend who refuses to do any remodel jobs. He says all you do is correct someone else's mistakes.
Let me describe, which I should have done in the beginning: the house is a split foyer. There are two Newel posts in the LR;One post is a half-Newel and I'll bet it is glued to the sheetrock. The other two are on the first set of steps down to the foyer. I could tape and paint the other post bases to match. Thanks!
all righty... let's knock this can of worms over...
is there a newel at the bottom of the stairs???
the half-newels need mechanical fastening...in the PDF's pick out what suits what you have the best and let us know and we can get on the same page...
can the pocket screw idea...
all plans are always subject to change...
pick one that may suit the mission......
Stair Railing, Post, Treads, Balusters, and Newels | Top Iron & Wood Supplies
one of my favorites...
and you can do this in matching woods and stains...
File Type: pdf 23_bracket-fix-system-installation-instructions.pdf (136.1 KB, 81 views)
fire65 likes this.
post #5 of 16 (permalink) Old 06-27-2015, 07:49 AM
First Name: Art
You're going to be fighting this all the way and it will never be strong. Stick's suggestion is the only easy way to do the job don't try to build up your newel post to make them higher this will only end up making things even weaker. To do the job right (remember what your friend said) you need to gain access to the stringer and lag the newel post there.
mgmine is online now
post #6 of 16 (permalink) Old 06-27-2015, 08:18 AM Thread Starter
Knothead47's Avatar
The half Newell in the LR is on the front wall and I'll bet it is glued to the sheetrock like the one at the top of the steps; there is a full Newell on the last step down to the foyer. The one at the top of the steps was glued to the sheetrock and there is nothing inside the guest closet to fasten it to except sheetrock. I would start from scratch but we have hardwood floors in the LR and I'm a believer in Murphy's Law. There is a piece of wood that runs on the floor for the balusters. My thinking is that it would be a bear to start over as the flooring might be too short unless I make a piece to fit. I've never had good luck with such things. stick486, I'll take time to look at what you have put on your post and go from there. Thanks.
Just a thought- might start from scratch and put the router table to use.
Edit- there might not be enough room for the trim stick486 shows in the picture.
John T.
post #7 of 16 (permalink) Old 06-27-2015, 09:06 AM
Contributor of the Month
Hello Stick,
I have seen the attachment set-up in your post. I need to do one for a round newel. Do you think there is a manufactured round one or will I have to fabricate myself?
JIMMIEM is offline
post #8 of 16 (permalink) Old 06-27-2015, 09:11 AM
please post a picture or five on what you have...
beats guessing...
post #9 of 16 (permalink) Old 06-27-2015, 10:18 AM
this can be done using the right bracket assembly and mounting procedure...
now all we need is the actual details to fill in the missing information to what really needs doing or what wants to be done so we can continue on or fall back to square one..
post #10 of 16 (permalink) Old 06-27-2015, 10:36 AM
Originally Posted by JIMMIEM View Post
Hello Stick,
yes there is...
there is base trim rings if you need them too...
Forum Ranks Mark Lobby 9 10-25-2011 11:24 PM
My Posts AxlMyk Site Help and Suggestions 1 07-28-2009 01:19 PM
