Cutting and fitting 45 deg. miter ends - Router Forums
 11Likes
post #1 of 22 (permalink) Old 07-17-2015, 07:51 AM Thread Starter
Knothead47's Avatar
Question Cutting and fitting 45 deg. miter ends
I have a couple of projects in mind. My dilemma is how to make trim or wood, cut at a 45 deg. angle and have them meet precisely the right length. This would be like trimming a table top or box with another type of wood. Is there a trick to making them the same lengths and fitting without a lot of trimming. Recommended way to cut? Am I making sense?
John T.
Knothead47 is offline
post #2 of 22 (permalink) Old 07-17-2015, 09:08 AM
rough cut to size...
use a shooting board final ....
I love my miter knife...
post #3 of 22 (permalink) Old 07-17-2015, 09:13 AM
BrianS's Avatar
First Name: Brian
I've only had success by the "trial and error" method. Cut one to fit, and slowly sneak up to a fit with the other piece, one shave at a time. I have seen some people use the "shooting board" method, but I've not tried it myself.
Brian
(Origin uncertain)
BrianS is offline
post #4 of 22 (permalink) Old 07-17-2015, 09:43 AM Thread Starter
Knothead47's Avatar
stick486, I'm impressed with the links. Several years ago, I helped my brother-in-law trim out a pantry that he got for his kitchen; it was to match is cabinetry. It was a bear trying to get the ends to meet precisely at the corners, both inside and outside.
John T.
post #5 of 22 (permalink) Old 07-17-2015, 09:54 AM
If the angles are both 45* and the boards are exactly the same thickness, then the heels and tips will match perfectly. If you are making a frame then the opposing sides also have to be the same lengths. The theory is simple. Getting it to work is harder.
One of the problems with using a saw is that the blade will deflect as it passes through late summer layers of wood. I've had better results when I used blade stiffeners with a good blade.
post #6 of 22 (permalink) Old 07-17-2015, 09:54 AM
That might be because the corners were just a tad out of square,as in most house construction. A sanding block with 40 grit cloth on it is handy to make adjustments on the spot to hand fit these joints.
On furniture it is a little different as the tolerances are tighter,and if care is taken in the build, for squareness, then less adjustment has to be made.
Herb Stoops is offline
post #7 of 22 (permalink) Old 07-17-2015, 10:41 AM
TwoSkies57's Avatar
Best ways to get it right the first time for me:
Favorite would be sneaking up on the miter with a shooting board.. SB has to be set up dead on..
Easiest would be sneaking up on the miter with a 12" disc sander. Jig for sander needs to be dead on..
Nice to have both with adjustable features...
When its just a lil bit of tweakin' required, a block with 100grit works for me..
I get my best results by working my way around, one corner at a time..
then sometimes ya just say AHHHHHHHHHH CRAP!!
I'd say that even one of those 6" disc /48" belt sander combo's would work well enough with the right kind of jig. The jig needs to be
rigid enough to hold the angle and even then a lil practice goes a long way. With the inside edge of miter resting against the
disc, apply a little pressure one way or the other to zero it in..
bcfunburst likes this.
Skipper the Penguin
TwoSkies57 is offline
post #8 of 22 (permalink) Old 07-17-2015, 11:17 AM
Contributor of the Month
A well adjusted miter saw should do it.
JIMMIEM is offline
post #9 of 22 (permalink) Old 07-17-2015, 11:35 AM Thread Starter
Knothead47's Avatar
Herb, should have explained in more detail. The pantry was attached to the end of existing cabinetry; we were cutting crown mold. It had one inside angle from the wall cabinet to the pantry; two outside angles on the top trim as the pantry was 24 inches deep.
If the wood isn't real thick, could a router with a 45 deg. bit work?
John T.
post #10 of 22 (permalink) Old 07-17-2015, 12:21 PM
cope the insides and a miter trim knife...
there's nothing like it..
