Advice on Cable Grommet Techniques - Router Forums
 10Likes
post #1 of 14 (permalink) Old 10-01-2015, 06:27 AM Thread Starter
First Name: Steve
Default Advice on Cable Grommet Techniques
Hi!
I need to install a cable grommet in the top surface of one of my projects. I've seen some of the commercial grommets, but I can't say that I'm overly impressed with the perceived quality or hide-ability. Some are plastic, some metal, and then I'm concerned about flush mounting them and coloring them to match.
I'm thinking about making a removable grommet out of the 3/4" wood top itself. Considering the use of hole saws & routing a lip. I'd be OK with a rectangular insert as well. Not exactly sure how I'd cut this part out such that it's a tight fit with minimal seams.
Once the insert is done, I'd drill out some holes for the cables to pass through. I'd like to have a second insert made with no cable holes if my devices are moved and I want it to look clean again.
Thanks for any advice to make this happen! Hope this wasn't confusing!
Steve
plunger is offline
post #2 of 14 (permalink) Old 10-01-2015, 06:47 AM
DonkeyHody's Avatar
First Name: Andy
I assume you're talking about a hole for wires to pass through - like in an entertainment center. I don't know why it needs a grommet at all. There's no sharp edges to cut the insulation on the wires; you just want it to look nice, right? If you're dealing with solid wood instead of ply, I'd just cut an appropriate sized hole and round over the edges. It'll be as unobtrusive as a hole in the top can be. Now as far as hiding it later, you're going to have to get more creative . . .
MT Stringer and gjackson52 like this.
DonkeyHody is offline
post #3 of 14 (permalink) Old 10-01-2015, 07:23 AM
I agree with Andy if it's a wooden top or in the back where it won't show. Just use a round over on it if thick enough or sand the edges.
If it is a laminated top then you need it for looks but most are meant for the flange to sit on the surface. Because of that it might not look right recessed. If you do recess it I would hope to find a drill the right size or use an expansion bit to start the hole and make the recess for the lip and then switch to a bit for drilling the body.
post #4 of 14 (permalink) Old 10-01-2015, 07:24 AM
OPG3's Avatar
First Name: Otis
Steve, That's actually EASY to do! Most anywhere you're going to need a "grommet" - one of the sides will NOT BE SEEN. A wooden one as you have described is simple in whatever shape you desire. Just make the part(s) (one with holes & one blank) and position an oversized piece of 1/4" MDF, etc. on the back. Ideally, you will make matching backer boards, as well - with each one having matching (small) screw holes - so that the obsolete one may be removed and the blank be installed - using the same (small) screws and holes.
This reminds me of something funny that I recently observed...I am very near completion of my new office desk for computer setup and reference table. It is 14'-3" long and 34" front-to-back. No legs, yet very sturdy - using a double cantilever design that my Dad taught me many years ago. There are electrical outlets below this desk, and I wanted the appearance and functionality to be perfect. I drilled 3- 1.25" diameter holes about 4 feet apart for grommet installation. I often utilize this size of grommets. Normally, I have several "on hand", but I had depleted my reserves - so I had them on my list for next shopping trip.
A few days later, Joy (my wife) and I went out for dinner and were very near a Home Depot in Lawrenceville, GA. An old man walked me to electrical and then to their selection of grommets. He offered black and white, plastic and metal. I told him black, plastic, 1.25" diameter - going through 3/4" plywood. The grommets he handed me looked perfect, but they were in a plastic bag. There was something curious about them - they were ONE-PIECE! I asked if he had an open bag of those grommets? He said, "No - let's just open this bag!" He then handed me one, and as I suspected; they were ONE PIECE!
If this isn't comical to anyone reading this, picture this potential scenario: I have 3- 1.25" diameter holes. The grommets are ONE PIECE! I put the grommets in-place (they each have one 3/8" diameter hole molded into the top). How on earth am I supposed to get a male or female end of an electrical cord through a hole 3/8" diameter? His answer was: "No problem - just cut-off one end of the cord, slip it through the hole and REATTACH the end of the cord!" It was all I could do to contain my laughter until I was out of his line of sight.
We then went to Lowes, where their 1.25" grommets were TWO-PIECES! Now, I do not have to cut the ends off of my new computer cabling! Hallelujah!
OPG3
Tweak everything!
OPG3 is offline
post #5 of 14 (permalink) Old 10-01-2015, 11:25 AM
Richelieu has what you need...
Metal Grommets - Richelieu Hardware
DaninVan is offline
post #6 of 14 (permalink) Old 10-02-2015, 06:17 AM Thread Starter
First Name: Steve
Yes, this is actually a fireplace mantel that I'm painting a color-matched off-white. I have a Xbox Kinect camera up top that I want to hide the thick black cable. For now, it will be installed and is in use. But, being something that's not part of the house I'd want to be able to hide the wire access if I move, remove out the Xbox, etc.
I already installed some "orange smurf tube" conduit that reaches the media center area so I just need to get the wire into the mantel body in some neat fashion. I designed the mantel to be easily removable with two screws.
@OPG3 14' is a big desk! Yes, I've seen those grommets at both Lowe's & HomeDepot. The two piece certainly work better! My concern is the color of the plastic. It doesn't match.
@DaninVan Thanks for the link. If I can't make the grommet color match I'd probably use the metal material.
plunger is offline
post #7 of 14 (permalink) Old 10-02-2015, 11:32 AM
MEBCWD's Avatar
This is how I made grommets for the 3 desks I have made. if the grommet is no longer needed then a drop-in solid insert is used.
Name:	Bottom side of grommet.jpg
Name:	Top of grommet.jpg
MEBCWD is online now
post #8 of 14 (permalink) Old 10-02-2015, 12:09 PM Thread Starter
First Name: Steve
Wow- those are exactly the type of grommets I would like to make. Can you explain the best way to make them to a beginner, Mike?
plunger is offline
post #9 of 14 (permalink) Old 10-02-2015, 01:54 PM
MT Stringer's Avatar
Measure twice...no make that thrice. I seem to always get the grommet location right in the way of the monitor!
Murtu01 likes this.
MT Stringer is offline
post #10 of 14 (permalink) Old 10-02-2015, 02:47 PM
Whoa! Nice grommets, Mike!!
(I'd be remiss if I didn't point out that they're one piece and that the OP wants two piece ones.)
DaninVan is offline
Porter Cable 7538 vs 7539... need advice Eveready117 General Routing 8 11-04-2014 09:29 AM
Porter Cable 690 Troubleshooting Advice Lynn1953 General Routing 14 09-14-2014 07:20 AM
Location of Sommerfeld's rubber grommet FSorace Table-mounted Routing 13 08-03-2011 10:19 PM
cable for router crafter DougO Jigs and Fixtures 9 07-01-2009 12:50 AM
Porter Cable circular saw crquack Tools and Woodworking 11 03-29-2009 06:33 PM
