Dado usage - Router Forums
 5Likes
post #1 of 18 (permalink) Old 11-05-2015, 01:13 PM Thread Starter
Default Dado usage
I am putting a starting shop together. I have a good starting set of tools I believe and the first project I have plans for includes using a Dado stack for several cuts/joints. I am wondering if the is safe and usable with a circular saw, or if it should only be used with the table saw. Also, is there a size restriction on the circular saw? (Seeing several circular saws differing in size).
Travis Scott is offline
post #2 of 18 (permalink) Old 11-05-2015, 01:31 PM
Not to be used on a circular saw ever. You could use a cutting guide with the CS and make multiple side by side cuts or you can use a similar guide and do it with a router bit. It was smart to ask and welcome to the forum.
billyjim and RainMan 2.0 like this.
post #3 of 18 (permalink) Old 11-05-2015, 01:55 PM
Semipro's Avatar
First Name: John_*
Welcome to the forum.
+1 on what Charles says,I have never tried it but do not think you can even mount a stack Dado set on a Circular saw !
MT Stringer likes this.
Thank You John
Semipro is online now
post #4 of 18 (permalink) Old 11-05-2015, 02:12 PM
Hey, Travis; welcome!
What they said re the circ. saw.
On the tablesaw, youre limited to about a 3/4" dado or channel of any kind.
a) that's all the dado set comes equipped to do
b) that's all you can squeeze on the arbour...even then you might need to take into account how much of the thread the arbour nut is grabbing when you tighten it up.
c) if you haven't already bought your dado set, don't buy the cheapest you can find, and for sure don't even think about the wobble type of dado blade...trust me , from personal experience you'll regret it (the ER in my case!)
e) 8" set on a 10 " saw is all you'll need. You're looking for a set that has all the pieces machined to give you a perfectly flat bottom of the cut...they don't all do that. Be prepared to spend a bit more for that quality!
First thing you'll need to do is make yourself some zero clearance inserts for the table saw's table. There's a ton of YouTube how to's as well as a bunch of threads here at the Forum...use the search tool...
Router Forums - Search Forums
Make a bunch of blanks as long as you're making one; you'll eventually need them.
Scott; work safely! and most important have fun. When it stops being enjoyable you're doing something wrong.
MT Stringer and Roy Drake like this.
DaninVan is offline
post #5 of 18 (permalink) Old 11-05-2015, 02:16 PM
schnewj's Avatar
Welcome to the forum, Scott. Glad you asked about the dado blade before you got yourself hurt.
If you take some time to fill out your profile, and let us know what tools you have available, the members will be better equipped to offer you some alternatives.
Why do you need to use a dado blade? Give us a little context and we will come up with something.
Again, welcome
Bill
schnewj is offline
post #6 of 18 (permalink) Old 11-05-2015, 02:18 PM
Oops, Sorry!!! I called you Scott instead of Travis...my bad...apologies. *embarrassment*
DaninVan is offline
post #7 of 18 (permalink) Old 11-05-2015, 02:36 PM
Nickp's Avatar
First Name: Nick
It takes a wise man to know when to ask a question...don't lose that sixth sense and you'll stay safe...
Welcome...
Nick
Nickp is offline
post #8 of 18 (permalink) Old 11-05-2015, 04:53 PM
Circular saws won't accept Dado blades in that they mount the blade on a short stub of a shaft with a bolt thru the center. On top of that the blade guards are not wide enough to accept a dado stack.
However, back in the day, when we were framing roofs with rafters we had a custom Skil 8" worm drive made with an extended shaft and a wider guard. We would bunk all the rafters on edge with the bottoms up and snap a chalk line across, the width of the birds mouth cut, and use that dado saw to run a cut across the stack thus cutting them in 2 passes. The saw would be tilted on the appropriate angle .
While they were bunked up we we would use a 16" diam. Makita tilted to the correct angle and cut the ridge angle cut on the top end of the rafter.
Use a hand held router and straight edge on plywood sheets and a table saw for narrow boards either as suggested in multiple cuts, or with a dado blade.
If you have a router table, you can do the narrow boards with a straight bit, but use a miter gauge or some kind of jig to hold and guide the pieces ,do not try to free hand cut them.
Herb Stoops is offline
post #9 of 18 (permalink) Old 11-06-2015, 07:47 AM
First Name: Art
As has bee said never try something like that. You can use a dado blade on some sliding miter saws such as the Rigid so this might be a duel purpose saw to consider once you have a table saw.
mgmine is offline
post #10 of 18 (permalink) Old 11-06-2015, 08:25 AM
RainMan 2.0's Avatar
Welcome to the forum Travis . If your budget is limited I'd opt for a used table saw with a Biesemeyer fence
Ok ,I never insulate
RainMan 2.0 is offline
Help designing a repetitive dado jig jevansoh Jigs and Fixtures 32 12-13-2014 10:52 AM
Dado on 2 sides of 3/4 plywood for cubby shelves aquilja4 General Routing 3 11-06-2009 08:17 AM
Adjustable Dado jig - setup problems rovenm Jigs and Fixtures 2 09-21-2009 02:06 PM
Adjusting groove & dado widths. rstermer Portable Routing 22 08-10-2009 04:39 AM
Dado cuts in plywood BK9MJE Tools and Woodworking 4 04-18-2009 01:28 PM
