Box finger joints - Router Forums
 49Likes
post #1 of 79 (permalink) Old 12-03-2015, 11:13 AM Thread Starter
Knothead47's Avatar
Default Box finger joints
I think there was something in Wood magazine a few years ago where a jig was made to cut finger joints on a TS with a dado blade. The article went on to show overlapping pieces so the finger joints could be cut at the same time on two corners of the box. Hope I'm making sense. Thought the same could be done on a router table.
Thanks.
John T.
Knothead47 is offline
post #2 of 79 (permalink) Old 12-04-2015, 05:28 AM
Thanks.
Will this help???
ksidwy likes this.
Stick486 is offline
post #3 of 79 (permalink) Old 12-04-2015, 11:03 AM
CharleyL's Avatar
First Name: Charley
Stick's jig is only one of many that you can find by Google searching "box joint jig" and "finger joint jig" on the internet. Look through them and decide which one you like best.
Most of these jigs can be used on either a table saw or a router table.
The trick with these is to make the "key" and the "space" between the key and the saw blade or router bit EXACTLY the same width that the saw blade or router bit cuts (and not the width of the blade or bit). You will also need to make the jig so there is no side to side play in your guiding method. Any slop or side-to-side movement of the sliding method of your jig will produce errors in the joint. If you stack the sides of your box on the jig and clamp them to the jig correctly it's possible to cut two corners of the box at the same time, but don't try this until you get the jig adjusted and have made a few successful box joint corners (A side to B side) that fit together well.
I've made more than a dozen different versions of these jigs over the years. Some were great and others not so great, but I now have an Incra I-Box jig. It's expensive, but it made cutting box joints of any size from 1/8" to about 1" per pin easy to set up for and easy to use, and it can be used on either a router table or a table saw (I prefer my table saw and Freud SBOX8 blade for 1/4 and 3/8 pins). Since getting the I-Box jig, all of my previous box joint jigs have become firewood.
Charley
gjackson52 likes this.
Central North Carolina
CharleyL is offline
post #4 of 79 (permalink) Old 12-04-2015, 11:14 AM
gjackson52's Avatar
First Name: Gary
I thought this was a very clever jig, but I don't think my skills are good enough to make it :-)
Screw advance box joint jig
Gary
Herb Stoops likes this.
gjackson52 is offline
post #5 of 79 (permalink) Old 12-04-2015, 11:29 AM
PhilBa's Avatar
First Name: phil
I agree with Charley. a good quality and easy to use box joint jig is way to go. I use an Incra LS positioner on my router table which makes it a snap. You can build box joint jigs that will work. Just be aware that you need good precision or you will have disappointing results. I've also built box joint jigs and it took a couple of tries to get to the point where I got decent results.
By the way, fingers joint has several meanings - in the US it usually means a joint for joining two boards to make a longer board like this
Though, I have heard UK folks use that term for box joints like this
Visit my shop website.
PhilBa is offline
post #6 of 79 (permalink) Old 12-04-2015, 12:31 PM
You are correct Phil. What most people call a box joint is better known as a finger joint. If you do a web search for finger joint that is overwhelmingly what the results will be. https://en.wikipedia.org/wiki/Finger_joint
The tapered finger splice joint is what many people like to call just a finger joint. https://en.wikipedia.org/wiki/Splice_joint and this one https://www.google.ca/search?q=taper...GsHCjwP0pJHABQ
post #7 of 79 (permalink) Old 12-04-2015, 04:19 PM
Box joints are squared off regardless of size. Finger joints taper.
post #8 of 79 (permalink) Old 12-04-2015, 07:10 PM
Not according to guys like Tage Frid Mike and he had more experience and knowledge of woodworking than you and me put together. Plus google searches don't bear you out. Even Wikipedia doesn't agree with you. "Finger joints are also called box joints" by almost every reference I have ever seen.
Stick486 likes this.
post #9 of 79 (permalink) Old 12-04-2015, 07:24 PM
thanks...
and agreed..
Stick486 is offline
post #10 of 79 (permalink) Old 12-04-2015, 08:46 PM
Yes Chuck, there is a great deal of inaccurate information out there. There are many "experts" on either side of the question of what to call the joints. Manufacturers almost universally use the descriptions I stated for their bits and jigs. This isn't something I pulled out of thin air, it is based on researching many companies web sites. This is also the terminology used by Bob and Rick Rosendahl who supported the formation of routerforums. I believe after 14 seasons on PBS they qualify as experts too.
Moz likes this.
Compound Angled Box Joints DHB Jigs and Fixtures 122 07-06-2013 04:48 AM
box corner joinery almost there Jigs and Fixtures 17 10-15-2012 08:08 AM
Box Joints mtcsmith New Member Introductions 6 08-14-2012 07:20 AM
Box Joint Basics - How wide is a finger? wbh1963 Starting Off 12 11-29-2011 07:44 AM
finger joints ron dwyer Tools and Woodworking 3 11-28-2004 11:44 AM
