Waterproofing Bathroom Buffet-Turned-Vanity - Router Forums
 12Likes
  • 5 Post By DonkeyHody
  • 1 Post By Shop guy
  • 4 Post By Cherryville Chuck
  • 1 Post By DaninVan
post #1 of 9 (permalink) Old 01-19-2016, 06:00 AM Thread Starter
Question Waterproofing Bathroom Buffet-Turned-Vanity
Hi, I'm going to paint an old buffet as a sink vanity and it's been sitting unfinished for several YEARS because I can't find a definitive answer as to what product to use to seal it with. After all of the time and effort I spent sanding and rebuilding it, I don't want to paint and seal it only to have it get ruined by using the wrong product.
I plan on painting it a satin black and had thought about using polyurethane but I used poly on a coffee table once, using several thick coats, and it eventually ended up yellowing and lifting/cracking on me.
I've been told to use clear acrylic, marine varnish, or Minwax waterbased oil modified poly.
Anyone have a definitive answer as to which one would be best and how thick to apply without worrying about lifting? I don't think yellowing would show on black as long as it didn't lift off.
kgbb is offline
post #2 of 9 (permalink) Old 01-19-2016, 07:55 AM
DonkeyHody's Avatar
First Name: Andy
Sorry, I don't have any expertise in that area. But we're going to beat you about the head and shoulders for painting it instead of stain and varnish.
billyjim, Shop guy, Nickp and 2 others like this.
DonkeyHody is offline
post #3 of 9 (permalink) Old 01-19-2016, 09:40 AM
First Name: Richard
Andy, I'll come help with the beating. Just let me know when
kgbb likes this.
Shop guy is offline
post #4 of 9 (permalink) Old 01-19-2016, 12:04 PM
I've read that there is no such thing as a totally waterproof finish there are only levels of water resistance. The most water resistant finish is catalyzed epoxy. It is also the hardest to put on an when it does eventually crack and need refinishing it is the hardest to repair. Oil based varnishes come next. The chemistry of finishes changes all the time so maybe there is one now that won't yellow but most probably still will and although the black should help hide that I think you will still be able to tell a difference.
DaninVan, Nickp, Murtu01 and 1 others like this.
post #5 of 9 (permalink) Old 01-19-2016, 08:26 PM
What Charles said, and you'd have to for sure do the vertical edges of the sink and faucet cutouts.
Premium Black FX Poxy Galaxy Countertop - Counter Top Epoxy
Bar Top Epoxy | Commercial Grade Bartop Epoxy
kgbb likes this.
DaninVan is online now
post #6 of 9 (permalink) Old 01-19-2016, 11:38 PM
The finish on a vanity needs to be splash-resistant, not waterproof - unless you're planning to let the cabinet fill up with water. A good quality satin lacquer should be more than adequate, look at what Sherwin Williams or similar manufacturer sells for finishing kitchen cabinets. Over the years, I've never had a problem with water damage to the edges of the sink cutout or holes for the faucet, a quality caulk job should keep any water from getting to these areas.
Many years ago, in my inexperience, I painted some kitchen cabinets a pale yellow to match the walls and then top coated them with polyurethane - looked good at first, but they definitely started to darken over the years, very noticeable against the painted walls. I would think that one of the new water-based acrylic polys would be a much better choice nowadays as they're not supposed to yellow (and I've added Trans-Tint to them to give a less "artificial" looking appearance to stained parts. There was a very good article in Fine Woodworking some years back covering painting cabinets and some mention of acrylic poly as a top coat to give better protection.
tomp913 is offline
post #7 of 9 (permalink) Old 01-21-2016, 12:04 AM
I think calking carefully around the openings will give you the seal needed to protect the edges. I would ask at a real paint store what you could use that was water resistant and would give you the kind of look you seek. Personally, I wouldn't use any plastic type coating. Any countertop you might use should keep the moisture away. A wooden top or laminate sounds like a very bad idea to me.
post #8 of 9 (permalink) Old 01-21-2016, 02:53 AM
" Personally, I wouldn't use any plastic type coating."
Oh ye of little faith!...
(wood+epoxy+water)
Rogerdodge likes this.
post #9 of 9 (permalink) Old 01-25-2016, 05:09 AM Thread Starter
It had too much damage to the veneer on the top and front so I had to paint it. Trust me, I would have preferred to stain it instead! I rebuilt the bun feet with a weird foam epoxy made for that and I spent about a month sanding and rebuilding it!
kgbb is offline
Looking for bathroom vanity plan fire angel Project Plans and How To 29 06-01-2013 11:07 PM
Finish for Bathroom Vanity Top MrsOkee The Finishing Touch 9 12-12-2012 06:18 AM
Bathroom vanity as first project? MrsOkee Starting Off 16 11-26-2010 10:58 PM
2x30" bathroom vanity? quantumburnz DIY and Renovation 5 03-06-2010 02:30 AM
Bathroom vanity redo lrr Show N' Tell 2 12-13-2006 07:46 PM
