Fanuc 160i series controller - Router Forums
post #1 of 6 (permalink) Old 05-12-2016, 11:03 PM Thread Starter
Default Fanuc 160i series controller
First of all Hello to all members of the forum.
Moving on to my question, I have a machine that recovers from a factory that had pulled and thinking of dismantling to recover parts, I hold the idea of trying to set it up and looking well is almost complete has 3 axis X, Y, Z and another small servo turn the spindle, but it has all mounted servos with drivers and all, in a first test feed only the controller that is a Fanuc 160i MA series and as it does not boot I get only a small square that can move with the mouse having the controller, but the only thing it does.
My question is whether with Mach3 can handle drivers who have this machine that are also Fanuc Model A06B-6096-H208 but unlike other drivers they communicate with the controller via two optical cables and then the question is if anyone knows a breakout board to work with these drivers and mach3
Thank you for your attention.
marcelo69 is offline
post #2 of 6 (permalink) Old 05-12-2016, 11:21 PM
welcome to the forums oh nameless person...
Stick486 is offline
post #3 of 6 (permalink) Old 05-13-2016, 01:26 AM
I don't think Mach 3 will handle this.
post #4 of 6 (permalink) Old 05-13-2016, 10:10 AM Thread Starter
Thanks Mike.
I would also like to try to keep the original controller, you should see that not boot so if anyone has knowledge of this would be easier to determine whether controller has a solution or has some procedure to power up
post #5 of 6 (permalink) Old 05-13-2016, 10:22 AM
If you do not have the manuals you should be able to download them. You could also try calling Fanuc for support.
post #6 of 6 (permalink) Old 05-13-2016, 11:21 AM
gjackson52's Avatar
First Name: Gary
Welcome to the forum.
Gary
gjackson52 is offline
Wanted: Wanted( The Router Workshop Video Series 8 & 9) wduchsch Woodworking Classifieds 0 01-30-2016 10:26 AM
Stepper Motor Driver VS stepper motor controller robotdigg CNC Routing 24 03-31-2014 06:46 PM
**New** Router Workshop Series 500 DVD - Available Now!! Mark Site Help and Suggestions 9 08-05-2007 05:07 AM
