Porter Cable 690 Locking Pin - Router Forums
 1Likes
  • 1 Post By tomp913
post #1 of 8 (permalink) Old 06-20-2016, 08:27 PM Thread Starter
rbm328's Avatar
First Name: Rich
Default Porter Cable 690 Locking Pin
I'm not an absolute nubie to routers, as i've been using my on and off for several years BUT, I have a question and the manual is the pits.
When i'm changing a bit, there is a little black pin i must push and hold in, to lock the shaft. i've been pushing the pin with one hand while trying to break the collet nut free with the other. this seems VERY awkard! am i doing it right?
thanks
rich
rbm328 is offline
post #2 of 8 (permalink) Old 06-20-2016, 09:30 PM
On a PC 690? All of mine require two wrenches to loosen/tighten the collet, there is no locking pin.
fire65 likes this.
tomp913 is online now
post #3 of 8 (permalink) Old 06-20-2016, 09:32 PM
VinnieLopez's Avatar
its probably best to remover the motor from the base and lay it on its side on a table. now press your spindle lock button and loosen using your wrench in the other hand. It is definitely awkward but if you position the motor so your thumb hits the button and the rest of your hand is holding the rest of the motor you should be ok.
A common goal of creating beautiful, unique and useful pieces that enrich our everyday lives.
VinnieLopez is offline
post #4 of 8 (permalink) Old 06-20-2016, 09:33 PM
the new version has a spindle lock button.
post #5 of 8 (permalink) Old 06-20-2016, 09:34 PM
scratch that I was wrong the 892 has a button.
post #6 of 8 (permalink) Old 06-20-2016, 10:02 PM
Honored Member
First Name: pat
I'd still use the 2 wrenches. For get the pin.
Quillman is offline
post #7 of 8 (permalink) Old 06-20-2016, 10:24 PM
I also find the ones that use two wrenches much easier than the ones with some kind of locking mechanism. One place I worked had a Makita, probably a 3612, that had a locking pin and it had gotten worn and didn't hold very well. No idea how hard it is to replace one if it happens so make sure you have it pushed in well before you try to unscrew the collet nut.
post #8 of 8 (permalink) Old 06-21-2016, 08:59 AM
Under the table, the locking pin is out of the way and you have to reach for it. Two wrenches in that case would be easier. The Triton's only negative to me is having to reach under to lock the shaft. Raising the table height makes that a little easier on the back.
Porter Cable 890 lock pin replacement fishinfusion Tools and Woodworking 2 03-25-2011 03:30 PM
Porter Cable 690 questions daveb89 Portable Routing 4 01-28-2011 08:15 PM
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
Porter Cable 690 PeterLowes General Routing 3 01-20-2009 12:57 PM
