Template routing small pieces without breaking - Router Forums
 7Likes
post #1 of 16 (permalink) Old 08-31-2016, 07:02 AM Thread Starter
Country: Greece
Default Template routing small pieces without breaking
Hello everyone!
I am a hobbyist woodworker and relatively new to routing.
I am trying to make a wooden part at the router table but I hit the wall every time!
I try to template route a small part (6mm - 1/4") using a Bosch straight flush trim bit (6mm diameter). Every time I try to route the edge, the bit catches and breaks the edge... I tried supporting the edge from the opposite direction of routing with wooden jigs but no success.
You can see the piece in the attached image (made with a jigsaw and a lot of sanding).
Any ideas or suggestions?
rogtek is offline
post #2 of 16 (permalink) Old 08-31-2016, 09:42 AM
Honored Member
First Name: pat
That ear produces short grain, a very vulnerable and weak section of the sample. If you take this cut in stages, say 1/16" - 3/32"/pass (in thickness), then the side load trying to break the part, is substantial reduced. You stand a better chance if you take the waste in 4 or 5 passes.
Templetizing this sample to prevent the failure, unless making 100's, will not be worth time.
Quillman is offline
post #3 of 16 (permalink) Old 08-31-2016, 09:52 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by rogtek View Post
Hello everyone!
There will always be a weakness using wood, is there any reason why you can't use MDF, preferably Melamine coated like the piece shown in the photo.
Harry
harrysin is online now
post #4 of 16 (permalink) Old 08-31-2016, 11:38 AM Thread Starter
Country: Greece
Thanks for your replies but...
This sample is made from pine which is very soft and the grain isn't oriented correctly. The final piece will be made from beech which is much harder and the grain is oriented correctly but I still get the same results. The problem is that I can't make fine passes by hand because the part is very small. If you are off by a fraction it breaks. As for the templating, I plan to make about 50 of them, but the real problem is that I can't make them identical to each other without templating.
As for the material used, I want to use only solid wood. If I manage a way, besides beech I am planning to make a few from walnut.
I am going to try to make a pass so that the cutter is oriented TO the wood from the one side and then switch the template upside down so that I can route the other side. But unfortunately the problem remains at the top.
rogtek is offline
post #5 of 16 (permalink) Old 08-31-2016, 12:33 PM
Hello everyone!
this can explain it better than I can...
harrysin and firstmuller like this.
post #6 of 16 (permalink) Old 08-31-2016, 02:32 PM
Honored Member
First Name: pat
Don't understand: " The problem is that I can't make fine passes by hand because the part is very small."
What's the size of the work have to do with depth of cut?
Quillman is offline
post #7 of 16 (permalink) Old 08-31-2016, 03:36 PM
Ok, a little different approach, since you're making 50 of them.
Route the shape in a long piece, or if you need a different grain orientation, cut the same profile in several short pieces. You'll wind up with what looks like a piece of molding. Then cut off pieces with a narrow kerf blade for your final result. Make the length at least twice what you think you'll need so you have some backup. Support the back of the piece with a sacrificial fence so that the cutoff piece is supported as the saw goes through. Still, I'd expect a number of pieces just won't make it--it's wood! Making these one off is not practical.
rjtwin501 and chuckgray like this.
post #8 of 16 (permalink) Old 08-31-2016, 04:33 PM
paduke's Avatar
I have been templating "2" high alphabet letters I have been using a 1/4" upcut spiral bit. The material is oak. 1/4" thick. I must use the scroll saw to remove waste to within a 1/16" There are still portions of some letters that I must scroll saw to complete. I break a few but it can be done
paduke is offline
post #9 of 16 (permalink) Old 08-31-2016, 04:48 PM Thread Starter
Country: Greece
An image may show the problem better. As you can see I can't feed the piece in the router bit because it's very thin. It's a matter of luck if you can make contact with the bit in a way that it won't rip the edge. I also noticed that by cutting the piece so that the grain follows the right direction, doesn't help much. The speed of the router bit is no match for this piece of wood...
rogtek is offline
post #10 of 16 (permalink) Old 08-31-2016, 05:26 PM
hawkeye10's Avatar
First Name: Don
I see you have made a router table and that is good. You might make the hole smaller so it will support that small piece better. Also try using some double stick tape and attach another board under you project for more support. Plywood would be good. A hair dryer or heat gun will make the tape easier to get off. Just throwing out a few suggestions.
JFPNCM, MEBCWD and jj777746 like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
Videos: Cutting small pieces Safely Gaffboat Tools and Woodworking 9 09-05-2014 08:44 AM
Feed Ddirection/Safe handling when template routing on the table? fleetinglyshort Table-mounted Routing 5 03-13-2014 12:20 PM
routing a small oval Thomas0668 General Routing 17 09-24-2012 03:02 PM
routing small pieces zxxer12 General Routing 9 03-21-2005 04:40 PM
Advanced (?) Template Routing billdcon Jigs and Fixtures 6 03-09-2005 01:07 PM
