Bit changes?? - Router Forums
 6Likes
post #1 of 13 (permalink) Old 10-15-2016, 05:22 AM Thread Starter
scribble79's Avatar
First Name: Chris
Default Bit changes??
Is your collet suppose to be very difficult to loosen enough to get the bit out. I've seen people change bits in videos and looks like a quarter turn of the wrench and the bit almost falls out. I seem to have to make 4-5 complete turns before I can get the bit out. I am using a dewalt 618 in a rockler plate if that matters.
Sent from my iPhone using Tapatalk
If you can't read it Scribble wrote it.
scribble79 is offline
post #2 of 13 (permalink) Old 10-15-2016, 05:51 AM
TWheels's Avatar
I don't know about the DeWalt system but the Makita 3612c and the Bosch MRC23EVSK system bit release is easy, for me maybe one full turn of the one(Makita) or two wrenches (Bosch).
Vegetarian Arthritic Paraplegic Wannabe Routerologist
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #3 of 13 (permalink) Old 10-15-2016, 08:09 AM
First Name: Steve
The dw618 has a catch that you have to loosen and then turn a little more and it tightens up, then you turn a little more to loosen. This is normal. I think it is built in as a fail asfe to keep the bit from coming loose while the machine is running. Don't know if this makes since to you but it is normal.
scribble79 likes this.
Knot2square is offline
post #4 of 13 (permalink) Old 10-15-2016, 08:18 AM
Gene Howe's Avatar
First Name: Gene
My PCs and Boschs require less than a full turn to loosen the collet so it can be finger turned. Then, after a few finger turns, all the PCs need the wrenches to get past a second tight spot before the bit can be removed.
JFPNCM and DaninVan like this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #5 of 13 (permalink) Old 10-15-2016, 08:52 AM
paduke's Avatar
It also allows you to insert bit, partially tighten, lift bit 1/8" and it will stay in place while you completely tighten
paduke is offline
post #6 of 13 (permalink) Old 10-15-2016, 09:16 AM Thread Starter
scribble79's Avatar
First Name: Chris
Too bad there are no auto spindle locks so you only need one hand to change. The button to release on the 618 seams to always be blocked and ther isn't much room for 2 wrenches in theer
post #7 of 13 (permalink) Old 10-15-2016, 09:44 AM
hawkeye10's Avatar
First Name: Don
I agree with Steve. I thought something was wrong with my DW618 until I asked the same question as you.
WurliTzerwilly likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 13 (permalink) Old 10-15-2016, 10:10 AM
WurliTzerwilly's Avatar
First Name: Alan
This has been the case on several European routers I've owned. It doesn't stop the bit from coming loose in the chuck, but it can't fly out. The Porter Cable I now use in my table doesn't have that facility.
Regards,
Alan.
WurliTzerwilly is offline
post #9 of 13 (permalink) Old 10-15-2016, 12:46 PM
JFPNCM's Avatar
First Name: Jon
Check out the Musclechuck. Quick Change Router Chuck - Camless Router Chuck - Dewalt - Porter Cable - Festool - Hitachi - Bosch - Makita - Trend - Freud - Fein - Metabo - Carvewright
A great alternative.
Jon
JFPNCM is online now
post #10 of 13 (permalink) Old 10-15-2016, 01:04 PM
My Hitachis are the same as Steve`s, Gene`s, and the others. You have to loosen twice.
Jon is correct that the Musclechuck is the only one handed type available. It tightens with an allen wrench and only requires one quarter turn and it reportedly holds more securely (4x) that a standard collet. It was developed by John DeRosa who is a member of the forum and he was giving forum members a discount in the past and may still be.
http://www.routerforums.com/general-...xtensions.html
Quick Change Camless Router Chuck Wood Working Accessories
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 05:18 AM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-20-2014 12:41 AM
Router Bit Woes - HELP! MT Stringer Router Bits - Types and Usage 14 10-24-2013 10:00 AM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 07:53 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 10:09 PM
