Simple overhead router frame - Router Forums
 8Likes
  • 4 Post By pinehunter
  • 1 Post By pinehunter
  • 3 Post By tomp913
post #1 of 10 (permalink) Old 10-19-2016, 03:27 AM Thread Starter
First Name: dave
Send a message via AIM to pinehunter
Default Simple overhead router frame
This is a DIY routing setup for cutting small circular pieces used for hubs for whirligig propelleSimple overhead router frame-dsc00359.jpgrs. The timber is located on a small pin which allows it to be rotated into the cutter.
pinehunter is offline
post #2 of 10 (permalink) Old 10-19-2016, 04:13 AM
this your creation Dave???
post #3 of 10 (permalink) Old 10-19-2016, 04:47 AM Thread Starter
First Name: dave
Hi Stick - Yes, it was originally made to machine curved mandolin faces. It was produced using DIY tools- largest drilled hole is 1/2". The uprights are 12mm round bar, router rails are 8mm round bar threaded m8 at one end, crossheads from 1"sq aluminium x 230mm long. Crosshead pinch bolts are m8 for uprights and m6 for router rails. Uprights are secured to board with m6 countersunk screws. Everything is adjustable and a fence can be fitted to board for normal machining.
Regards
dave
post #4 of 10 (permalink) Old 10-19-2016, 06:10 AM
nicely done...
many here refer to those as skis...
search ''ski'' w/ an extended date and watch out...
post #5 of 10 (permalink) Old 10-19-2016, 10:10 AM
JFPNCM's Avatar
First Name: Jon
Indeed an interesting approach to the "ski" concept.
Jon
JFPNCM is offline
post #6 of 10 (permalink) Old 10-19-2016, 10:40 AM
Originally Posted by pinehunter View Post
This is a DIY routing setup for cutting small circular pieces used for hubs for whirligig propelleAttachment 239154rs. The timber is located on a small pin which allows it to be rotated into the cutter.
@pinehunter
So, for the operation shown, the router remains stationary and the wood is rotated around the 1/4" locator pin? Do you cut almost through the wood with the router and then finish off the operation by hand? If not, you must have a pretty steady hand to not "bump" the cutter as the outer part is cut loose.
tomp913 is offline
post #7 of 10 (permalink) Old 10-19-2016, 10:47 AM
Country: Mexico
First Name: Joseph Anthony
Question
Originally Posted by tomp913 View Post
@pinehunter
Same questions here. And we need more pics in different angles.
Cheers.
Joe
RÖENTGEEP is offline
post #8 of 10 (permalink) Old 10-19-2016, 11:21 AM Thread Starter
First Name: dave
Hi tomp913 - The timber is located on a pin 2.5mm in dia. The router is adjusted to the hub size and clamped. The dark square of material under the pine acts as a spelch piece and the cutter is adjusted to penetrate 1-2mm into it and complete the cutting. The trick is to gang cut pieces so that hands are well away from the cutter as the timber is rotated . During the last section of cutting the pin holds the circular piece in alignment with the cutter. The waste may come into contact with the cutter but you should be able to prevent this by firmly holding the waste. I have a trick to make 2.5mm pins that screw into base board if needed.
Regards
dave
tomp913 likes this.
post #9 of 10 (permalink) Old 10-19-2016, 12:43 PM
Regards
dave
An interesting approach Dave. Most others are rotating the router around the circle. I agree no matter which way you do it the work should be secured to a sacrificial surface under it. Some pin all the way through into it and others use double sided tape.
post #10 of 10 (permalink) Old 10-19-2016, 02:51 PM
Regards
dave
Not sure that my hands (or nerves) are that steady any more. Based on a method used by @harrysin , I came up with the idea of using pins in the support board to retain the parts while routing. I drilled 3/4" holes in the support to accept short pieces of 3/4" dowel with a double-ended blind nail in the end, With the spacing adjusted to match the part being cut - to miss the router bit - the ends of the nails hold the parts securely for routing. I've used this to put roundovers on the edges of small plywood rings as well as to cut larger rings out of a piece of plywood.
tomp913 is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 01:48 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 12:44 PM
Grizzly G1035 Shaper vs Router Table GAVolunteer Table-mounted Routing 11 06-30-2010 07:35 AM
