Whirligig prop to resemble wind turbine - Router Forums
 8Likes
  • 8 Post By pinehunter
post #1 of 6 (permalink) Old 10-20-2016, 12:30 PM Thread Starter
First Name: dave
Send a message via AIM to pinehunter
Default Whirligig prop to resemble wind turbine
A prop to look like a commercial wind turbine.Whirligig prop to resemble wind turbine-dsc00379.jpg
pinehunter is offline
post #2 of 6 (permalink) Old 10-21-2016, 08:39 AM
Bushwhacker's Avatar
First Name: David
Nice job Dave
When the enemy is in range, so are you.
Bushwhacker is online now
post #3 of 6 (permalink) Old 10-21-2016, 08:45 AM
you definitely have yur act together Dave...
post #4 of 6 (permalink) Old 10-21-2016, 08:51 AM
MEBCWD's Avatar
What whirligig does that go on?
MEBCWD is offline
post #5 of 6 (permalink) Old 10-21-2016, 10:30 AM Thread Starter
First Name: dave
Hi Mike - the prop will be attached to shaped timber block to look like a generator housing which connects to a circular tower similar to the real world wind turbine [I HOPE!!]. It will have a directional fin in the shape of mount Fuji. A timber chassis will support tower and mount Fuji and will rotate to align with the wind on a pin made from a nail ground to a point and bearing on the cruciform head of a cross head screw located in the chassis at the balance point [I HOPE!!].
Regards
dave
WARNING- The road to hell is paved with good intentions - see above for details!!!
post #6 of 6 (permalink) Old 10-21-2016, 05:12 PM
MEBCWD's Avatar
Sounds interesting, waiting to see the finished project.
I really like the shape of that prop.
MEBCWD is offline
4 blade whirligig prop pinehunter Table-mounted Routing 6 10-25-2016 02:26 AM
Wood Prep- wind turbine blades andyrose The Finishing Touch 9 11-04-2015 12:22 PM
Power to the People! DaninVan Lobby 19 06-09-2015 12:13 PM
Would our academic members like to comment harrysin Lobby 2096 01-30-2015 02:54 PM
Wind farm efficiency Tempest Lobby 8 04-07-2011 12:21 PM
