Trimming wood edge banding - Router Forums
 8Likes
  • 8 Post By Cherryville Chuck
post #1 of 5 (permalink) Old 10-28-2016, 09:15 PM Thread Starter
Default Trimming wood edge banding
I've tried several ways to trim wood banding that has been applied to melamine, mdf, or plywood. The way I tried last night turned out to be the fastest and easiest of all the ways that I've tried it so far. The idea isn't new, it is a method used on a table saw where you add an auxiliary fence onto your standard one but lift it off the saw surface enough so that the banding goes under it. Then you set the rig up so that the outer edge of the saw blade is flush with the outside edge of the auxiliary fence and run the work through on edge.
I had never thought of trying that on a router table before but all you have to do is add a spacer under the fence so that you leave enough gap for the edge banding to go under and then set the fence flush with the bit. Quick and easy.
Name:	trimming edge banding 001.jpg
Name:	trimming edge banding 002.jpg
post #2 of 5 (permalink) Old 10-28-2016, 09:43 PM
JOAT's Avatar
First Name: Theo
Yeah, I would use the router too. But my method is pretty crude compared to yours. About everything I make, I nail masters to them, holds them nicely, and the nail holes will be hidden in the finished product. For things like you did, I tack a straightedge along the side, set so I can rout the whatever off nice and neat. Nice for making straight edges too.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is online now
post #3 of 5 (permalink) Old 10-29-2016, 12:02 PM
Nickp's Avatar
First Name: Nick
That's the way to keep it simple...great solution...
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #4 of 5 (permalink) Old 10-29-2016, 03:38 PM
TenGees's Avatar
First Name: Paul
Nice. I imagine that you could even use a small round-over.
TenGees is offline
post #5 of 5 (permalink) Old 10-29-2016, 08:09 PM
Good tip, Charles.
Sydney, Australia
jw2170 is offline
choosing an edge guide to do inlaid banding tomcoleman General Routing 22 05-20-2016 09:53 AM
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 01:03 PM
How I Found Free And Inexpensive Wood Over The Past Three Months tkleff Starting Off 51 12-16-2012 08:40 PM
Heritage Wood Specialties kp91 Tool Reviews 5 04-08-2012 09:51 PM
Edge trimming Melamine garryjc Portable Routing 1 06-14-2010 09:13 PM
