slot or T track - Router Forums
 5Likes
post #1 of 23 (permalink) Old 11-05-2016, 11:16 PM Thread Starter
First Name: Carey
Default slot or T track
Hi could anyone tell me which would be better a slot like in kreg tables or T track for an incra base setup. I have an incra 43" table which is 43" deep x 24' wide. With this table set up for the original incra jig it has to be mounted on a ply/mdf base across the back of the table but adjustable forward and backwards. I am not sure how to set up this adjustment travel. I can cut a slot about 26" long on either side about 4' in fom each side but worried about weakening the table. The other option is to rout out for an aluminium T track and bolt thru the table either side. The table is 1.25" thick
Any suggestions for a first time poster and newbie at woodworking especially routing. I will have Triton TRA001 setup with an aluminium wooed peckers plate in an Incra frame
jj777746 likes this.
Woiim is offline
post #2 of 23 (permalink) Old 11-06-2016, 12:47 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
usually a T track is only used for clamping stuff down, like the fence.
A U channel or slot track is used for stuff that needs to move across the table, like a mitre fence.
Best of both worlds would be a small length of T track front to back either side of the router to hold the fence tight, and a slot across the width in front of the router to allow the sliding mitre to travel across.
Like this
https://www.google.com.cy/search?q=r...GVjK8S9mPeM%3A
sunnybob is offline
post #3 of 23 (permalink) Old 11-06-2016, 01:19 AM
First Name: Clay
I have no idea what the question is.
fire65 is offline
post #4 of 23 (permalink) Old 11-06-2016, 01:22 AM Thread Starter
First Name: Carey
I probably didn't describe it properly. What I meant by slot is the full depth of table slot where you put a bolt right through the table and slide it backwards and forwards in a long slot
Woiim is offline
post #5 of 23 (permalink) Old 11-06-2016, 01:46 AM Thread Starter
First Name: Carey
Pretty basic really what do normal tables have on them for locking down fences, slotted holes right through the table or T track
fire65 likes this.
Woiim is offline
post #6 of 23 (permalink) Old 11-06-2016, 01:08 AM
T track. Slotted holes will weaken the top and it is much slower to bolt something through the table but at the same time I have no idea what you would need to attach to the table that would require that. Many of us don't have t track or a miter slot. You don't have to have either one but some like them. It's a matter of preference. The last fence I made I used t track. This one and all the ones prior to the last one got clamped with F clamps to the table. You can clamp featherboards too if you make them long enough.
post #7 of 23 (permalink) Old 11-06-2016, 01:53 AM Thread Starter
First Name: Carey
Thanks for that I will go with T track. The Incra setup requires a sliding adjustable ply wood base to traverse the adjustment required when doing dove tails and box joints
Woiim is offline
post #8 of 23 (permalink) Old 11-06-2016, 06:05 AM
paduke's Avatar
Welcome to the forum carrie You do not sound like a woodworking newbie.
for ideas on your incra you might enjoy http://www.routerforums.com/table-mo...ter-table.html for different ideas
paduke is offline
post #9 of 23 (permalink) Old 11-06-2016, 06:29 AM
Nickp's Avatar
First Name: Nick
Welcome, Carey...
I may have missed it...are you installing the Incra positioner...? the 17 or the 25...?
Are you talking about a base to mount the positioner to that needs to move ? or are you installing your own fence and it needs to move 26"...?
As I understand it, the base for the Incra does not need to move 26"...just wondering...
Nick
Nickp is online now
post #10 of 23 (permalink) Old 11-06-2016, 06:58 AM
First Name: Earl
I'm with Nick here. The 43" table from Incra comes predrilled for the positioner base (3 pairs of holes if I recall correctly. If you're using the 17" LS positioner, use the front (closest to the plate) holes most of the time, and it's less than 4 minutes to move to the back position for the times you need to be farther back. Unless your work requires switching between the two on a regular basis, i'd not cut the table. If you have to change that often, i'd probably think about picking up a 25" positioner--the arm itself can be bought to swap out--or pick up a 25" system and sell the 17" and one might net a little less out of pocket cost.
earl
greenacres2 is offline
Router miter slot vs track jetjocky New Member Introductions 10 01-24-2015 08:14 PM
T Track vs T Slot Router Bit Selwyn Senior Router Bits - Types and Usage 3 02-23-2014 08:29 PM
Slot for combo track drummy General Routing 11 07-15-2013 04:18 PM
Bit for cutting slot for Miter Track Racer2007 Table-mounted Routing 4 08-31-2011 11:01 PM
Mitre slot : straight or T-slot? matt1710 Table-mounted Routing 5 05-10-2011 09:55 PM
