More sliding fence box joint issues - Page 2 - Router Forums
 55Likes
post #11 of 60 (permalink) Old 11-16-2016, 10:21 AM
Knothead47's Avatar
I tried making dovetails and finger joints, using El Cheapo plywood from the Big Blue Store. It was a disaster! Wrote off using plywood for dovetails or box joints. In the future, I will use quality, solid wood just for the ease of cutting on a TS or router table.
Herb Stoops likes this.
John T.
Knothead47 is offline
post #12 of 60 (permalink) Old 11-16-2016, 03:47 PM Thread Starter
I was recommended to use a spiral cutter for this job. I'm confused about "up cutter" and "down cutter" when used in a router table. Since these are blind slots, I think I want a spiral up cutter so it pulls the chips down out of the slot, yes?
Thanks to all for the advice, I'll let you know how I'm doing as it goes.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #13 of 60 (permalink) Old 11-16-2016, 05:09 PM
Chas if you are drilling a mortice or blind slot you want an up spiral to move chips out. If you are trimming an edge or using a guide bushing and template and you don't want the top edge ragged then you use a down spiral. If you are going all the way through and you want the bottom side with a clean edge you go up spiral again. If you want both edges clean you use a compression bit (and of course more money for those).
post #14 of 60 (permalink) Old 11-16-2016, 09:48 PM
I agree with @Knothead47 and use the Drawerlock bit for all my plywood drawers. It is so simple and does a beautiful job. And the box joints for my solid wood boxes. Plywood does not work for me for dovetails or box joints.
Herb Stoops is offline
post #15 of 60 (permalink) Old 11-16-2016, 10:37 PM
I gotta disagree w/ you both...
not only that.. GIVE HIM A BREAK...
instead of trying to discourage... encourage...
everybody started someplace...
Chas is just now in his learning curve and he is trying hard to master these box joints...
so he's using them on drawers... he'll move on to plan ''B'' and we'll help him there too...
wanna bet fine box jointed boxes by CW are on the horizon..
and take the easy route on drawer corners.. do the corners w/ rebated rabbets...
post #16 of 60 (permalink) Old 11-17-2016, 12:41 AM
RainMan 2.0's Avatar
I agree with you guys , seeing as plywood is small layers laminated together , it must be a headache not getting tear out .
I'd love to know how someone pulled this off . Table saw ?
Ok ,I never insulate
RainMan 2.0 is online now
post #17 of 60 (permalink) Old 11-17-2016, 05:18 AM
Rick...
you see the density of layers??
resin based glue has saturated the veneer layers and added to the fiber cohesiveness of the veneers...
they may even be ultrasonically welded making them a close 2nd to solid wood...
could even be HRF cured/welded.... again, making them the other close 2nd to solid wood...
then they are most likely CNC cut w/ spiral or compression bit...
at some point he is going to end up w/ up, down, helix or compression spiral bits...
each has their place...
COMPRESSION bit:
The part of the bit closest to the tip is upcut and the other end is downcut... That is why it’s called a compression bit. It compresses the chips into the center of the bit.
It’s great for cutting openings in wood..... This makes it especially great for plywood, laminates and MDF when you need both the top and bottom edges clean. You just have to make sure that the piece of wood you are cutting is thick enough so that both ends of the bit have room to work.....
Spiral Router Bits vs. Straight Router Bits Page 1
Router Bits - Up-Cut, Down-Cut and Now, Quadra-Cut. / Rockler How-to
post #18 of 60 (permalink) Old 11-17-2016, 05:27 AM
Default @CharlesWebster
these may help you out a bit...
post #19 of 60 (permalink) Old 11-17-2016, 08:26 AM
First Name: Art
I gotta disagree w/ you both...................
Stick I'm confused I thought that is what he was using the box joints for, hence my reply to make a traditional carpenter's drawer and not use box joints.
mgmine is offline
post #20 of 60 (permalink) Old 11-17-2016, 09:05 AM
Knothead47's Avatar
Stick, I read you Lima Charlie. Yes, we all started out sometime in the past. When I got my first lathe, my first turning was a piece of pine and a wood chisel. Not the best way to start but later bought a set of turning tools from HF. Not the best but do the job for me......until I get some $$$$ to buy some better quality tools. Trying to get the wife to go back to work but she just gives me the evil eye.
Rainman's photo is outstanding. Curious how it was done and where the plywood came from. Never seen any like that.
John T.
Help with Rockler Box Joint Jig... Marty in DC New Member Introductions 10 02-14-2014 06:20 PM
Kreg Precision router fence #PRS1010 TwoSkies57 Table-mounted Routing 2 06-29-2013 01:45 PM
Learning How to Make a Tissue Box Cover learnexperience General Routing 2 12-05-2011 06:56 PM
Box joint jig update horn man Jigs and Fixtures 9 01-07-2010 11:19 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 09:52 AM
