Zero clearance fence inserts - Router Forums
post #1 of 32 (permalink) Old 11-28-2008, 10:28 PM Thread Starter
Bogydave's Avatar
First Name: Dave
Default Zero clearance fence inserts
Wanting to make some "zero clearance" inserts (for various bits) for the router table fence.
I learned it's better to ask here before I get something that don't work.
What is the best way to make & lock them in the fence?
Life isn't right, wrong or fair. Life just is.
Bogydave is offline
post #2 of 32 (permalink) Old 11-28-2008, 11:14 PM
HI Dave
The best way is to use a T & G bits,,,BUT it takes a bit of work when you want more so to say a 10 deg.miter works very well...and is a lot quicker when you want more
post #3 of 32 (permalink) Old 11-29-2008, 12:29 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
There are several advantages in using a tall fence as I do, one of which is it's easy to clamp a strip of thin MDF, typically 3mm, to the fence and withdraw the fence through the cutter to give a genuine ZERO clearance opening as shown.
I've probably posted the pics in reverse order, but not to worry Bj!
Harry
harrysin is offline
post #4 of 32 (permalink) Old 11-29-2008, 09:13 AM
Ghidrah's Avatar
First Name: Ronald
That's an awful lot of fences to maintain!
What advantage is there over a split fence?
Ghidrah is offline
post #5 of 32 (permalink) Old 11-29-2008, 10:45 AM
dovetail_65's Avatar
First Name: Dovetail
I really do not like the split fence. A split fence is mostly used for jointing, other than that I find it a PITA.
I like to use the pivoting fence and pull the fence into the bit to make a true zero clearance fence. The T& G method for each insert like Bob shows looks cool, I have nothing more than a miter that holds my inserts in like on the CMT fences. Some bit shapes do not leave as clean results when pivoting in to the bits as pulling in both sides of the fence continuously. So for some bit shapes I don't pivot into the bit.
Seeing Bobs method with the T&G I may go there when my current fences need updating.
Harry's tall fence is sweet too.
I like my inserts at least 3/4" though, the same thickness as my fence.
It's one fence and many inserts so there is only one fence to maintain.
I think the benefit over a split fence is there is no adjustment to hassle with. I am sure we all at one time or another have been pushing stock through to find it got caught up on the outfeed fence. The zero clearance of course provides smoother chatter free cutting and probably better dust collection depending on how you collect the dust.
dovetail_65 is offline
post #6 of 32 (permalink) Old 11-29-2008, 02:14 PM Thread Starter
Bogydave's Avatar
First Name: Dave
Thanks Harry, BJ, Nick.
Gives me ideas to work with.
Probably go with Harry's method first. simple & easy (KISS)
Definitely see the advantages of T&G. but that's down the road, will need new fence faces & get good enough to make the T&G - nuts on. (well, me making a T&G at all will require another new bit order )
Definitely see the need for more than one table & a few fences for each. Didn't know when I made the router table that it was creating a "living organism" that will continually grow. I see many more fun & challenges ahead. For now I plan to get my first table as usable as I can, already see I'm going to modify & add new fence fronts. Clamps, hold downs, bit guards, stop block slots & others.
Thanks again
Dave
Bogydave is offline
post #7 of 32 (permalink) Old 11-29-2008, 02:20 PM
Hi Nick
I really like the split fence,,the CMT fence comes with the slide in bars to offset the fence quick and easy,,( 1/16" and 1/32" offset steel bars) that's one of the main reason I got the CMT setup..that and the swing fence..
I use it any time I use a router bit takes off the edge of the stock..or to say puts on a sharp edge on the stock..like a miter bit,lock-miter bit,etc.
post #8 of 32 (permalink) Old 11-29-2008, 02:46 PM
Hi Dave
You're Welcome for my SMALL part..
But it looks like you are 1/2 way there..
Thanks again
Dave
Name:	dave fence.jpg
post #9 of 32 (permalink) Old 11-29-2008, 04:04 PM
Hi Nick
Well the CMT is neat in that it is a solid one piece fence that can be made to act as a split fence shimming the HPDE fence face on the outfeed side. I actually have two of the fences but never use them for jointing. I could though.
I was referring to a traditional two piece split fence, I just do not like them.
post #10 of 32 (permalink) Old 11-30-2008, 02:43 AM Thread Starter
Bogydave's Avatar
First Name: Dave
I have 6" between the sliding fences. 45 deg. 2 - 1/2 mdf glued together with formica on the face. If this is enough room, I make the zero clearance inserts a little thicker & plane them down to the right thickness 1-1/32" I think (a piece of 3/4 & 1/2 glued together)
Do they need to be taller than the sliding fence?
Do I need to add a "hold down" or is the friction fit between the 45s OK?
Bogydave is offline
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 7 03-16-2010 09:08 AM
CMT Industrio Router Table System (orange cabinet) Ladd Table-mounted Routing 51 03-08-2010 11:29 AM
TS zero clearance inserts Router is still my name Tools and Woodworking 1 06-13-2008 12:39 AM
