Side fence - Router Forums
 8Likes
  • 7 Post By Tiny
  • 1 Post By Marco
post #1 of 4 (permalink) Old 12-30-2016, 02:27 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Default Side fence
Im not shure If this is the Fight place for this. I desided to start making the routertable from the side fence. The bottom is Wide So it can be clamped if needed. This is MkI but MkII IS already on my mind.
Esko
My profession is to restore old loghouses that is in the classical way. Look at www.tiny-e.fi and (FB) Tiny-e. Restaurointipalvelut for exaples
Tiny is offline
post #2 of 4 (permalink) Old 12-30-2016, 03:09 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
The MkII will propably have T-profile to atach fingers (not my) or other things.
Esko
Tiny is offline
post #3 of 4 (permalink) Old 12-30-2016, 05:25 PM
Honored Member
First Name: pat
Have studied the fence issue for a long time.
You have more to sweat than just clamping. That fence will
not remain flat nor square to the table. A plastic cover (paper phenolic?) will occlude one side
of the ply and the other side will cup or bow.
Better to make it out of aluminum, plastic, even MDF will stay flatter. Moreover, Finnish or Baltic Birch will change shape too.
A great fence to get your feet wet on but not for long run.
Quillman is offline
post #4 of 4 (permalink) Old 12-30-2016, 07:45 PM
Marco's Avatar
Hi Tiny... you have a good start on your first fence!
Under the heading of "Everyone has one" my opinion/observation on a first time Router Table build is is to build your table first and then fit/make your fence to the table. Build it and use it as soon as you can and you will see what you need to add to the table and fence. A lot of the bells and whistles are not used depending on what you are routing. An example of a basic table for the cost of a few bolts is here....
If you are clamping the fence to the table you would not need slots for the bolts and wing nuts to go through. Keep in mind that any straight piece of wood can be clamped down to your table and called a fence. If you buy a Router Plate invest your money in a good heavy duty one. Good luck, have fun and be safe.
ksidwy likes this.
Galatians 5:13
Marco is offline
Which edge guide? Dan_T Portable Routing 37 01-05-2015 07:50 AM
new fence stripper Tools and Woodworking 13 02-08-2014 10:03 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
A Poor Man's adjustable Positioning Fence Stefang Table-mounted Routing 8 02-26-2010 04:22 AM
New Router Table RustyW Show N' Tell 10 08-28-2006 02:23 AM
