Bit for edge jointing - Router Forums
 2Likes
  • 2 Post By Cherryville Chuck
post #1 of 7 (permalink) Old 01-18-2017, 12:35 PM Thread Starter
First Name: ED
Default Bit for edge jointing
I would like to what the best router bit would be for edge jointing on my table mounted router.
I need to edge joint some 3/8" thick red oak.
I have a Hitachi KM12VC router and a Bosch RA1181 table. Bosch supplied some 1/16" spacers for jointing.
I do not have a jointer.
We have a small shop in the senior residence I live in and not much space for big power tools.
Edmentzer605 is offline
post #2 of 7 (permalink) Old 01-18-2017, 01:34 PM
Hi Ed and welcome. Normally you just use a straight bit with the fence and it sounds like you are already aware of offsetting the outfeed. I would use at least a 3/4" D bit but my feelings are that bigger is better. 1/16" may be too big a bite. A 32nd or less may be better. Plastic playing cards make good shims for the outfeed as they are very uniform in thickness.
Semipro and Herb Stoops like this.
post #3 of 7 (permalink) Old 01-18-2017, 02:00 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I use pieces of card wedged behind the outfeed fence, the kind that you get as a backing card on notebooks. Thats a half mm thick and it works a treat.
I also would think 1/16" would be a big bite for oak. Multiple passes at a thinner setting will be less stressful on the machine and the bit.
sunnybob is offline
post #4 of 7 (permalink) Old 01-18-2017, 02:49 PM
vchiarelli's Avatar
First Name: Vince
I've used a piece of laminate behind the outfeed fence and found that that is a good thickness for removal of material - a small piece the length of the outfeed fence shouldn't be too hard to scrounge.
vchiarelli is offline
post #5 of 7 (permalink) Old 01-18-2017, 03:30 PM Thread Starter
First Name: ED
Hi All,
I was worried about taking a 1/16" cut and will something about 1/32". Thank for the advice. I have used a hand held router in the past but am new to a table mounted router. My router fits the table very well. I used the table for making some drawer sides, worked great.
I have a MCLS 3/4" bit which I will use.
Ed
post #6 of 7 (permalink) Old 01-18-2017, 04:06 PM
adapt this to your happiness....
post #7 of 7 (permalink) Old 01-18-2017, 05:13 PM
Honored Member
First Name: pat
Some pointers. And I would keep the waste to within 1/32" too. It takes a lot of power to waste a full thickness.
I'd be using 2.5-3.25HP at full speed.
Quillman is offline
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
Sears Router bit description gary smyth Jigs and Fixtures 4 07-18-2011 12:38 AM
Sears Router bit description gary smyth General Routing 1 06-30-2011 10:23 PM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
