router repair - Router Forums
 5Likes
  • 1 Post By Stick486
  • 3 Post By Daikusan
  • 1 Post By CharleyL
post #1 of 6 (permalink) Old 01-30-2017, 08:30 PM Thread Starter
Default router repair
Is there a good YouTube to show changing brushes in a 1618 router?
erm4545 is offline
post #2 of 6 (permalink) Old 01-31-2017, 12:40 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Most brush changing is extremely simple.
Undo the cap on the outside, and look. The brush is held in with a metal spring, and usually the wire has an eye for a screw connection. Sometimes its soldered, but thats all there is. carefully lever up the spring, insert the new brush. Do what is needed to swap over the wires. put the cap back. job done.
sunnybob is online now
post #3 of 6 (permalink) Old 01-31-2017, 01:15 AM
Looking at the parts diagram it appears you need to remove the top cap and maybe another part or two. Bosch 1618 Parts List and Diagram - (0601618039) : eReplacementParts.com part number 816 is the brush assembly.
post #4 of 6 (permalink) Old 01-31-2017, 01:22 AM
your '18 router has the same motor as the 1617....
the brushes are under the black plastic caps that are located on opposing sides of the upper motor housing...
remove the caps...
remove the old brushes...
reassemble...
File Type: pdf Diagnosing Electric Power Tools 101.pdf (386.8 KB, 65 views)
jj777746 likes this.
Stick486 is offline
post #5 of 6 (permalink) Old 01-31-2017, 02:38 AM
Daikusan's Avatar
Country: Japan
First Name: Steve
Dont forget to make sure the thing is unplugged. . . .
Im not saying you would do that but there are people out there who would. They might find it shocking!!!
TenGees, jj777746 and Lucky Irish like this.
Workmanship is not perfection; it is how well you can cover your mistakes.
Daikusan is offline
post #6 of 6 (permalink) Old 01-31-2017, 11:25 AM
CharleyL's Avatar
First Name: Charley
There is always a spring involved. Be prepared to hang onto it, or it might fly to the most impossible to find place. In routers with screw on side caps covering the brushes, the caps are what usually become airborne. It's a relatively simple job to change brushes, if you don't loose something in the process.
Charley
BrianS likes this.
Central North Carolina
CharleyL is offline
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 12:48 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
Bosch 1617EVS router repair chiswoo Starting Off 6 07-02-2007 05:30 PM
