Shop built router lift motor? - Router Forums
 3Likes
  • 2 Post By Stick486
  • 1 Post By Cherryville Chuck
post #1 of 4 (permalink) Old 02-18-2017, 07:19 PM Thread Starter
repeters1's Avatar
First Name: Pete
Default Shop built router lift motor?
I have been wanting to build a router lift for some time now and have found many plans on line to do this.
My problem is almost all of these plans don't say what type of router motor they are using.
I want to build one that uses a motor only instead of one I have and that I use by hand.
I'm guessing my first thought is one that I can use either 1/4" - 1/2" collets, variable speed (although I do have a 20 amp 120 Volt router reducer),and locking shaft.
I've seen a few in local pawn shops that work but the bodies have cracks in them or pieces missing. maybe cannibalize something like these?
If you have one of these setups, let me know which router you have used and how it's worked out.
Thanks,
Pete
If it's not broken, break it, then fix it.
repeters1 is offline
post #2 of 4 (permalink) Old 02-18-2017, 07:21 PM
Bosch 1617 motor...
the top of the heap...
repeters1 and denniswoody like this.
post #3 of 4 (permalink) Old 02-18-2017, 10:48 PM
Any motor that comes out of the case will work. You should have the motor before you start the lift because there are different diameters.
repeters1 likes this.
post #4 of 4 (permalink) Old 03-03-2017, 07:40 PM Thread Starter
repeters1's Avatar
First Name: Pete
Thanks for that info. I'm going to see what's available at my local pawnshops.
I'll post something once I find one I like.
Pete
Sent from my SM-T350 using Tapatalk
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
Best router for a shop built router table awg General Routing 6 02-07-2012 11:34 AM
Shop built router lift? TanOak Table-mounted Routing 51 09-13-2010 03:17 AM
Router lift or router with built in lift? asfestus Table-mounted Routing 2 10-26-2008 11:20 AM
Old Glossary Terms Mark Site Help and Suggestions 0 10-14-2008 02:30 AM
